| Vista Ultimate x64 | E6850 Oc problem vista 64 bsod when stress test Am having a hard time trying to get my system stable on vista ultimate 64 on xp pro 32 bit it worked greatam getting the bsod when i run orthos prime 95 and occt VCORE 1.42V FSB CORE 1.4V FSB 1616 @3.636Ghz Memory 2.1V I added more virtual memory Initial size (MB) 4393 Maximum size (MB) 6139 and it seems the bsod stopped but orthos and prime 95 will get errors and stop 3 to 4 hours in instead of bsod in 3 min into it So far gaming on crysis, cod4, assassins creed, guild wars, call of juarez, ut3, star trek armada 2 and command and conquer tibwars and kanes wraith i have not crashed or locked up only games i lock up on or crash are bf2142 and bfme2 and droped down the fsb from 1616 to 1600 or 400fsb depends on how you look @ it. but still with overclock and stock i still get errors any ideas why? Last edited by Saberous; 08-31-2008 at 02:23 AM.. |
| Vista Ultimate x64 | Re: E6850 Oc problem vista 64 bsod when stress test Hm.. well you should be able to hit 3.6 GHz decently easy.. and with less volts than that. I can hit that with my Quad on those volts. I know all chips are different. but you should be able to hit that.. Have you tried loosening the RAM timings.. have you done anything with ram to Rule the RAM out first? changed Divider or something. |
| Vista Ultimate x64 | Re: E6850 Oc problem vista 64 bsod when stress test I have messed with the times of the ram and up the volts i have tried 5-5-5-15-2t timings 5-4-4-15-2t timings i have up the volts of the ram to 2.2V i don't now what other timing to try and sugestions but i am thinking its ram related |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: E6850 Oc problem vista 64 bsod when stress test What timings does the mobo set for the RAM in auto mode? |
| Vista Ultimate x64 | Re: E6850 Oc problem vista 64 bsod when stress test 5-5-5-15-2t right now am running @ 5-4-4-15-2t. am not bsod when i run stress tests am running 2 dual kits of OCZ Technology | Products | Memory | OCZ DDR2 PC2-6400 SLI-Ready Edition Dual Channel there is a 4GB Dual Channel Kit and am running those timing for all four sticks which made it more stable. OCZ Technology | Products | Memory | OCZ DDR2 PC2-6400 SLI-Ready Edition 4GB Dual Channel |
| | #6 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: E6850 Oc problem vista 64 bsod when stress test Running dual dual kits may be your problem - the nVidia chipsets (especially the 6xx and 7xx series) have issues with running 4 DIMMs at one time. |
| | #7 (permalink) |
| Vista Ultimate x64 | Re: E6850 Oc problem vista 64 bsod when stress test thats what i was thinking, my buddy has 780i ftw editionwith the same ram and four gigs and he dosent have any problems |
| | #8 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: E6850 Oc problem vista 64 bsod when stress test Supposedly the 7xx series is also problematic, however, I remember many more posts about the 6xx than the 7xx. With the 7xx I think including that cheapo fan for the Northbridge helped alleviate *some* of the problems, but there is a 'mobo mod' out there in the eVGA forums about the 780 where you can take a 60mm x 20mm fan and wire tie it to the radiator fins and plug it into the aux fan Power source instead of the NB fan Power source, and it runs a lot faster - seems the mobo limits the juice going through the NB fan power source.... |
| | #9 (permalink) |
| Vista Ultimate x64 | Re: E6850 Oc problem vista 64 bsod when stress test Supposedly the 7xx series is also problematic, however, I remember many more posts about the 6xx than the 7xx. With the 7xx I think including that cheapo fan for the Northbridge helped alleviate *some* of the problems, but there is a 'mobo mod' out there in the eVGA forums about the 780 where you can take a 60mm x 20mm fan and wire tie it to the radiator fins and plug it into the aux fan Power source instead of the NB fan Power source, and it runs a lot faster - seems the mobo limits the juice going through the NB fan power source.... so a 2x2 dual kit would be better then i take it? |
| | #10 (permalink) |
| Vista Ultimate x64 | Re: E6850 Oc problem vista 64 bsod when stress test Ya thats what people say.. But you can get better timings with the 4x1. but it's easier on the Mobo to have 2x2. Thats what I have. Also when I said are you messing with the Timings. I didn't mean go lower. If your having problems getting your OC to be stable. and you are pretty sure you have enough vcore. then try "Loosening" your RAM timings. I know that ram is rated for 800 MHz at 5-5-5-15. or maybe less cuz it's 800.. prob 5-4-4-12 or something. But with an OC. I'd try loosening them to like 5-6-6-16 T2 and see if it makes it stable. When you think the ram is the problem. Give the RAM enough Juice. Make sure your runnin what the MFG spec is for the ram at that speed. and then try loosening the RAM. gives it a easier time. for a more stable clock. just what I've been able to do. is loosen them for better results. |
| Intel C2D E6850 | Overclocking & Cooling | |||
| CPU and Memory Stress | General Discussion | |||
| hard self test problem with Vista | Vista hardware & devices | |||
| RC1: BSOD during "Performance test" | Vista installation & setup | |||
| post powershell stress syndrome | PowerShell | |||
