Vista - Fan Speed Control and Overclocking
Old 09-04-2008   #1 (permalink)
Vista Ultimate 32bit
Is there any way to control the fan speeds on the system? I checked the bios but since my fans arn't stock (upgraded) they dont appear. No Vista option for the fan speeds either. I have downloaded various programs, SpeedFan ect, but none seem to make my runs run at 100% Its always ranging from 50% to 60%.
Also, are there any good programs to overclock the CPU? I'm having alot of trouble with my MSI Neo P45 motherboard. I've got the right components and all, but it wont let me overclock my QX6700 past 2.8 when it was 2.66. I want to at least get it to 3.44ghz.
Old 09-04-2008   #2 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Re: Fan Speed Control and Overclocking
Not sure what's going on with your fans are you sure they are supposed to run at 100% ? - are the correct options enabled in the Bios - worth checking the manual or get it from your mobo's website - also see if they have an updated Bios available.
CPUID has oc'ing functions - it warns you it's at your own risk, of course - they also do HWMonitor which should help you see what's going on with your fans and temps.
CPUID
Hope this does the trick
SIW2
Old 09-05-2008   #3 (permalink)
Vista Ultimate x64
CPUId has Oc'n fucntions. I've never known that. lol
Your fans should not be going at 100 percent. and you should for sure be able to OC that thing plenty far.. how far is your RAM Oc'd. Try setting Ram to unlinked. and set it at stock 800, then add a little voltage and crank that thing to 3.33 GHz. I'd try that first. just set the fsb to 1333. and you can probably make that on stock volts. I can hit 3.33 GHz on stock volts on my Q6700 no X edition. I run mine Daily at 3.66 GHz these days. used to be 3.5 but 3.66 GHz is my sweeeeet spot I'd decided. I've gotten it to 3.7 Ghz also.
What cooler do you have?
Does WSR have a speed versus accuracy control like Dragon does? Vista General
I like the CPU speed control in Power-->Advaanced settings, with p Vista General
Fan speed control Graphic cards
Again: MS Mouse Pointer Speed Control - but WIN XP Prof. Vista General
MS Mouse Pointer Speed Control Vista General
