Vista - watercooling system radiator
Old 10-23-2008   #1 (permalink)
home premium vista (64bit)
hello
can someone please help me understand just how a watercooling system radiator
works? as i see it is the water gets cooled in the radiator by just a fan. if
this is so then it can only get around your system or room temp or maybe 1c. or
2c. cooler is this right ? i'm trying to learn as much as i can on this cause i
read on some posts that posters are cooling there system down to like (16c. to 20c.) on water. how can that be if it's just cooling by a fan?
thanks
scrooge
Old 10-23-2008   #2 (permalink)
Vista Ultimate 64bit SP2/
Re: watercooling system radiator
This might help you understand scrooge easier.
How does Water Cooling work?
Old 10-23-2008   #3 (permalink)
mansrm81 thanks for your help
i got the EVERCOOL EC-WC-202 CPU & GPU Water Cooler Kit as a starter for watercooling and found it don't work for me at all.thats why i'm looking for the info on the radiator thinking maybe this one is not cooling it right. i had a (NINJA PLUS Rev.B 6 Heat Pipes CPU Cooler with fan) on my system before and it cooled my system better then the water. i tryed resetting the block and still can't get the temps down any lower then 44c. with the ninja i was getting 39c. anyway thanks again for your help.
scrooge
Old 10-23-2008   #4 (permalink)
Vistax64
my WC system cools down to 22C - I am also using nanofluids as my fluid. Are you sure you don't have any air trapped in the water block? Is your pump turned to max? You can always slow it back down. make sure nothing is blocking the radiator fan intake..make sure you have enough liquid in the system, and make sure nothing is blocking the air flow thru the radiator
Old 10-23-2008   #5 (permalink)
do you have the same watercooler? on this one i don't see any settings for the pump.only settings i see is for the fan on top of the radiator and it don't seem to pump much air to the radiator .i have it set all the way up and don't seem to do much. i just ordered a (Swiftech MCR320-QP Quiet Power radiator) thinking that may do the trick . also let me ask you this, how much paste did you put on the cpu? this one says to cover evenly on the surface of the cpu core. i was always told to only put a small amount in the center of the cpu core.
thanks
scrooge
Old 10-23-2008   #6 (permalink)
Vistax64
a small dab of thermal paste will work just fine. I usually spread mine out, but the force of the block should do that. I don't thin I have the same water cooler. My fan speed is constant, while I can change my pump speed.
Sounds like your fan might be bad..it should be blowing some air
Old 10-23-2008   #7 (permalink)
it blows the air in but it don't seem to be real strong. so maybe the Swiftech will cool it down then .
hey thanks again for all your help.
scrooge
Old 10-23-2008   #8 (permalink)
Vistax64
is the fan able to draw air easily? - nothing in the way and it is not right up against a wall of any kind? and, the system is full of water?
Old 10-23-2008   #9 (permalink)
yes i left the tray on top open and the tray below open. i'm thinking the fan just don't cool the radiator to well . theres 2 radiators in the loop a small one connected
to the back wall of the system and the other sets in bay.
thanks
scrooge
Old 10-23-2008   #10 (permalink)
Vistax64
have any case fans laying around? I try one of those..good luck
New to watercooling Overclocking & Cooling
Programs - Replace System Program without Modifying System Files or Permissions Tutorials
System.OutOfMemoryException thrown by System.Threading.Thread.Slee .NET General
Vista Blocking Shared System Drive when in WinXP (Dual Boot System) Vista security
Issues with System drive in Disk Management on a Dual Boot system Vista General
