| Windows 7 x64 | 4 pin to 3 pin fan cable I have a Zalman 9700-NT cooler, which uses a 4 pin connector to connect to the motherboard, but I want it to connect to my fan controller, so I can have direct control to when I want to lower it, only problem is the extension cables that came with the fan controller can't connect to a 4 pin cpu fan connector, they're all 3 pin. Anyone know where I could find a 4 pin to 3 pin fan cable? I've had a look around, but not having much luck. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: 4 pin to 3 pin fan cable |
| Windows 7 x64 | Re: 4 pin to 3 pin fan cable I can't seem to find an actual 4 pin male fan connector. So would I be able to just use a 3 pin connector like this: ![]() As I read the 4th connection isn't actually always needed? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: 4 pin to 3 pin fan cable Everlong, Yes, you connect it that way. I found this at Intel to help make it easy. Pin 1 will be for the red wire. Desktop Boards - 3-Pin and 4-Pin Fan Connectors |
| Windows 7 x64 | Re: 4 pin to 3 pin fan cable Thanks a lot |
| | #6 (permalink) |
| Vista x64 Ultimate | Re: 4 pin to 3 pin fan cable cyberguys.com might have them. |
| | #7 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: 4 pin to 3 pin fan cable You're welcome Everlong. |
| Cannot connect to internet using Ethernet Cable but can connect with USB cable | Network & Sharing | |||
| Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H | Vista General | |||
| setting up cable TV: WMC can't detect cable signal | Vista General | |||
| VGA Cable | Vista hardware & devices | |||
| No cable | Vista networking & sharing | |||
