Vista - How can i raise the Coolers Speed?
Old 11-11-2008   #1 (permalink)
Vista Ultimate Edition x64
How can i raise the coolers speed from my GPU ?? It is getting WAY too hot.
It gets 110C when im playing, and 100C when im not.
I have a gaming laptop, called Asus G2s
Old 11-11-2008   #2 (permalink)
Vista Ultimate x64
Re: How can i raise the Coolers Speed?
As far as I know the only way is with a bios update (that is what Dell did for their laptops with the same graphics chips). Only problem with that is it is only a band-aid solution and not a real fix. Pick your link,
nividia failing mobile - Google Search
but they all come down to the same thing, the only wya to fix it is to have it repaired by the laptop manufacturer.
Old 11-11-2008   #3 (permalink)
Vista x64 + Windows 7 x64 (Ultimate)
And here I am worriying when my GPU hits 55 to 60 degree celsius!
Are you sure those temps are not in Farenheit?
Old 11-11-2008   #4 (permalink)
Quote  Quote: Originally Posted by AstaLaVista View Post
Sure thing ..
I can't deliver it to asus because asus won't send it back to Brazil.
Asus just delivers it to USA And Canada
Old 11-11-2008   #5 (permalink)
Vista Ultimate x64
Ouch.
You can try RivaTuner,
RivaTuner
no promises as it even says right on the page,
Quote:
Note: RivaTuner doesn't declare official support for mobile graphics processors and multi-GPU SLI and Crossfire configurations. Proper functionality on such systems is not guaranteed, use RivaTuner at your own risk.
If you do try it don't try and do anything more than increasing the fan speed.
Old 11-12-2008   #6 (permalink)
Vista Ultimate x64
Do not overclock or anything..
alsot he nvidia 8600Mobile line is known to overheat and cause issues. they had a Huge millions and millions in recalls for many of there mobile cards.
sorry to say that. but I'd try to increase fan speed.. but do not overclock the GPU at all. plus it's always good to get a lap cooler. or those little Cooler pads for Laptops. look into that
Old 11-12-2008   #7 (permalink)
Quote  Quote: Originally Posted by xguntherc View Post
Thats what i wanted, to raise the fan speed.
And, in Rivatuner, I CANT raise the fan speed.
I think it doesn't support.
Would it be clever to underclock the GPU?
How does one raise "administrator/administration" in Vista? Vista General
How Can a Server Raise an Event at a Client (Remoting) .NET General
Last days to Help Microsoft raise $100k for Aussie kids! Vista News
Network speed is half or one third of speed on XP Vista General
How to check your Speed Boost tested memory speed Vista General
