Vista - Fan cooling
Old 11-19-2008   #1 (permalink)
Windows 7 Ultimate 64bit
Fan cooling
When do you have the best results with fan cooling?
With open case or with closed case?
And why?
Old 11-19-2008   #2 (permalink)
Vista home premium 64 bit
Re: Fan cooling
The computer works best with the side on.
This is because of the airflow from the front fan to the back/side fans.
Old 11-19-2008   #3 (permalink)
Vista Ultimate x64 sp1
reading is my game - learning is my trade - from what i gathered - bring in the cool air to the units - get the hot air out - if u have the side wall off - u lose the stream line of the towers design -
i was going though a heating prob - my reason i was packing too much power in a stock tower - if ur gonna go big - u def need a better tower - u can only fit so much motor in a ford escort
Biggest and best cooling Overclocking & Cooling
Cooling a 9800GX2 Graphic cards
Cooling BallistiX Overclocking & Cooling
Solved Air Cooling praise Overclocking & Cooling
What cooling PAD Should i choose? General Discussion
