| Vista Home Premium 32bit | overclocking my pc help....NOOb i want to overclock . other forums are not tooo help full. i have a hp a6042N with a 19inch lccd monitor. the only upgrade on my pc is 2gb of cosiar ram. 1x1gb ram stick. it i THINK includes memory coolers. i think tha because it doesnt have the grean color like my old ones. 2 x512mb ram. 32bits 3gb ram 500mb videocard?? i dont know why but it says i have a 128mb video card but it shows up as a 500mb video card my specs Field Value Computer Operating System Microsoft Windows Vista Home Edition OS Service Pack Service Pack 1 DirectX 4.09.00.0904 (DirectX 9.0c) Computer Name (sumthing) User Name ultra preformance Motherboard CPU Type Unknown, 2200 MHz Motherboard Name Unknown Motherboard Chipset Unknown System Memory 2944 MB BIOS Type Award (03/02/07) Display Video Adapter GeForce 6150SE nForce 430 Monitor HP w1907 Wide LCD Monitor [NoDB] (CND7050NMT) Multimedia Audio Adapter High Definition Audio Controller [NoDB] Storage IDE Controller Standard Dual Channel PCI IDE Controller SCSI/RAID Controller Microsoft iSCSI Initiator SCSI/RAID Controller NVIDIA nForce Serial ATA Controller SCSI/RAID Controller NVIDIA nForce Serial ATA Controller Disk Drive Generic- SM/xD-Picture USB Device Disk Drive Generic- SD/MMC USB Device Disk Drive Generic- MS/MS-Pro USB Device Disk Drive U2120705 FLASH DISK USB Device (117 MB, USB) Disk Drive USB 2.0 SD/MMC Reader USB Device (1882 MB, USB) Disk Drive ST332082 0AS SCSI Disk Device (298 GB) Disk Drive Generic- Compact Flash USB Device Optical Drive HL-DT-ST DVDRRW GSA-H20L ATA Device SMART Hard Disks Status Unknown Partitions C: (NTFS) 256902 MB (161249 MB free) D: (NTFS) 7859 MB (707 MB free) E: (NTFS) 20478 MB (3278 MB free) Z: (NTFS) 19998 MB (16410 MB free) Total Size 298.1 GB (177.4 GB free) Input Keyboard Enhanced Multimedia PS/2 Keyboard Mouse PS/2 Compatible Mouse Network Network Adapter NVIDIA nForce Networking Controller (192.168.1.47) Modem PCI Soft Data Fax Modem with SmartCP Peripherals Printer Brother MFC-240C USB Printer Printer Brother PC-FAX v.2 Printer Microsoft XPS Document Writer Printer Send To OneNote 2007 USB1 Controller Standard OpenHCD USB Host Controller [NoDB] USB2 Controller Standard Enhanced PCI to USB Host Controller [NoDB] USB Device USB Mass Storage Device USB Device USB Mass Storage Device USB Device USB Mass Storage Device Problems & Suggestions Problem Disk free space is only 9% on drive D:. |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: overclocking my pc help....NOOb The first problem is that you need to identify your components correctly first. If your RAM has metal/aluminium on them, then you most likely have have RAM with heat spreaders. I suspect that your VC is only 128mb. Everest: (shareware limitations, but still usefull) Lavalys - Comprehensive IT Security and Management GPU-Z: Details about your Video Card techPowerUp! :: Downloads CPU-Z: Details about your CPU CPUID SIW (like Everest, but free) http://www.gtopala.com/download/siw-setup.exe Since it's a HP computer, your overclocking *may/most likely* will be pretty limited by what you can do in the BIOS. Try the apps and get to know a bit more about your PC before trying to overclock it You also probably have a stock CPU cooler which is not good to use for overclocking.I'm not trying to be discouraging, but what do you hope to achieve by overclocking? |
| Vista Ultimate 64bit SP2/ | Re: overclocking my pc help....NOOb You won't be able to overclock anything on the motherboard you have cause HP locks the bios. You will only be able to overclock an aftermarket graphics card. Only certain brands from HP you can overclock. |
| Vista x64 + Windows 7 x64 (Ultimate) | Re: overclocking my pc help....NOOb For the most part, Branded PC's do not make good Overclockers because they use cheap Motherboards to begin with... this is all hearsay though as I have never had a Dell or HP pc but it is what I read on other forums. |
| Vista Ultimate x64 | Re: overclocking my pc help....NOOb AstaLaVista it isn't so much that they use cheap motherboards, it is more that they use motherboards that are the same as what you can buy. The boards may be missing a few features from the retail version, but the big one is they lock the bios from any changes like overclocking; and it isn't so much that the bios is locked, it is that those options just aren't visible. If you get a Dell or HP that has a motherboard in it that is identical to a retail board you could theoretically flash it with the retail board's bios and open those options up. Only problem with that is that then you will no longer have a Dell or HP computer, especially as far as Windows is concerned. |
| | #6 (permalink) |
| Vista Ultimate x64 | Re: overclocking my pc help....NOOb they get the same boards most others use, and have. yet HP disables many of the features. Overclocking is Not very realistic or possible with a HP,Dell, Emachines.. all those. You're best bet is to get a new Graphics card.. and overclock it. for some better gameplay. and other than that your good as the new 2GB of ram was your best upgrade. as Vista needs 2GB to run "well" Also, after reading your info above, you only have onboard video.. not an actually grapics card. so you can't overclock that either. Get a new GFX Card.. like a Nvidia 8800GT, or a 9800GTX. and you'll be happy! |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: overclocking my pc help....NOOb i dont play games. well kinda. but im kinda too old. i am a animation expert. working woth 3ds max studio 2009. it takes a heck lotta of cpu to run it. I need more cpu because it takes plain too long to render a 200 frame scene. i work by projeccts. i wan to overclock because i might get faster times. but there is one mega question in my mind. should i just but a quad core and fit it in with my ecs mobo.? i always thought u needed a mobo that is strong enough to support ur cpu. u guy sound like that not true? so which is it?? |
| | #8 (permalink) |
| Vista Home Premium 32bit | Re: overclocking my pc help....NOOb a 200scene render takes me 8 hour i'v tried everything..even brinks tutorials. |
| | #9 (permalink) |
| Windows 7 x64 | Re: overclocking my pc help....NOOb As long as the mobo has the socket and FSB to support the processor you want, it should fit. Your DXDIAG doesn't actually say what processor you have, for whatever reason, but lets say it's a 2.2GHz Core 2 Duo, a 1066MHz FSB. You could get the Q6600 quad core CPU and it will work in your mobo. Another thing also is, and I'm not sure how much it will help, but you could look at getting a new graphic card too and installing CUDA drivers for it, which helps offload CPU intensive things and lets the graphic card render it, and it has proved to be a lot more efficient as a graphic card has say 128 cores in the GPU as an example of a 9800GTX+. |
| | #10 (permalink) |
| Vista Home Premium 32bit | Re: overclocking my pc help....NOOb ok. before u leave. i have a amd 64x2 4200+ suppports 64 bits but i dont know how to upgrade. maybe another day ![]() back to my question. can u tell me what cpu i can buy that will suport it? |
| OverClocking NoOb.... Some Help from the Vista Gods? | Overclocking & Cooling | |||
| Need help (noob) | General Discussion | |||
| Noob here... | Overclocking & Cooling | |||
| Hello, noOb here | Vista General | |||
| plz help im a noob | Vista General | |||
