Vista - Diferent types of cooling.
Old 03-25-2009   #11 (permalink)
Windows 7 x64
Re: Diferent types of cooling.
Quote  Quote: Originally Posted by Gnys View Post
Quote  Quote: Originally Posted by moirae View Post
I'm trying to find the review I read the other day. Was from one of the smaller tech sites around...but they were using my card and THAT cooler...which is why I was interested...The results were kinda good. Especially for the cost involved.
I'm seriously gimped at work...half the interwebs that I try to search are blocked...will look into it tonight...
**EDIT: I'm a scrub. From what I can find...Idle temps with one of those coolers is around 35-37 degrees...Load temps are 50-60 ish. They STILL absolutely smash most coolers on the market***
Apologies if I mislead anyone. The 37 degree figure must have stuck in my mind. They still look like a solid solution to me :P
Those Thermalright's are serious coolers for sure but honestly man on full load the GPU will get around 50~ and that is still hot, you know that but better than 70~ for sure. Wouldn't be to hyped with nickel as it's still not the lightest metal (titanium, platinum & aluminum) but much better than copper for sure. Best solution, liquid cool these beats but it's costly.
That VGA cooler that was linked is copper. It's nickel plated. Titanium and platinum coolers aren't all that common either. Aluminum are somewhat common, but a copper cooler with a decent fan can still do a good job of cooling.
Old 04-06-2009   #12 (permalink)
Windows Vista Ultimate x64 Build 6001 and Windows 7 Ultimate x64 RC Build 7100
Well thank you everyone, i am definetly staying with air cooling, I am going to invest in a Coolermaster HAF 932 anywho, now i just have to wait till R* sort the problems out GTA IV and the 200 series cards, if they do.
Thanks for all your opinions everyone
Old 04-06-2009   #13 (permalink)
Vista Ultimate x64
Good case. Good choice.
Manually control the fan on the card and you wont have an issue with temps...A lot of air moves through that case.
Old 04-06-2009   #14 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
That it does
One example - My current idle state temps: (core 1,3,4 are stuck )
Old 04-07-2009   #15 (permalink)
Vista Ultimate x64
VERY similar to mine :P
Nice work.
Old 04-07-2009   #16 (permalink)
Cheers mate. With the amount of air flowing through our cases, they'd want to be
Old 04-07-2009   #17 (permalink)
Vista Ultimate x64
I've needed every single fan on my case this past summer. My study where I keep all my pc stuff has no air-con. (Its coming, will be in before next year)...
At times it has been like sitting next to a space heater on my desk.
Video card just throws out so much heat :P
Cooler months coming up. Already seeing awesome temps while under load. Barely cracking 40 degrees....makes me happy.
is possible to install windows updates in a diferent partition? Windows Updates
Fan cooling Overclocking & Cooling
Cooling BallistiX Overclocking & Cooling
diferent language windows, same pass, works? Vista General
