| | #11 (permalink) |
| Vista Ultimate x64 SP1 | Re: OverClocking NoOb.... Some Help from the Vista Gods? I'm in the process of the 'reading, -re-reading and reading some more' before I over-clock my rig. I don't really need the extra speed boost from an i7 965, but look at Intel's own website-the chip has been MADE TO BE OVER-CLOCKED. I'm using an Asus P6T Deluxe V2. Asus themselves claim that the board is 'one of the easiest OC boards on the market today.' This board comes with utilities to over-clock! My RAM? Corsair Dominator 1600 (OC) Oh yeah... the OC is for 'over-clock' As for heat issues, there are fan and air systems that are as good as water-cooled systems. The Cooler Master Hyper N520 isn't top of the line, but it cools almost as good as a water cooler, which is dangerous to motherboards, RAM and CPU's! Get a vibration caused leak in your system, or just forget to leak test before firing it up-you'll kick your own butt for not going with a air-cooler solution. Oh yeah, my GPU is an eVGA GTX 285 SSC @ 702mHz. This card CAME over-clocked. Over-clock if it's something you want to do to get the most for your money. I paid a K for a CPU that's expected to OC'ed. If I can end up with even 3.5 gHz per core, I've got a system that's not going to be obsolete for at least a couple of years. Just my thoughts on the subject... |
| | #12 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: OverClocking NoOb.... Some Help from the Vista Gods? |
| | #13 (permalink) |
| Windows 7 x64 | Re: OverClocking NoOb.... Some Help from the Vista Gods? |
| | #14 (permalink) |
| Vista NoOb Issue | System Security | |||
| overclocking my pc help....NOOb | Overclocking & Cooling | |||
| Networking gods not pleased with Vista and SBS on the same network | Vista networking & sharing | |||
| How in gods name do you uninstall a Display Adapter cleany in Vista? | Vista hardware & devices | |||
| Vista Noob Question | Vista General | |||
