Vista - GPU running very hot at idle.
Old 04-02-2009   #11 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: GPU running very hot a idle.
Quote  Quote: Originally Posted by MrNeeds View Post
correct me if im wrong, doesnt the 7300SE use passive cooling(no fan)? you could get an exhaust fan sucking air from the gpu and blow it out the back of the case, may be a cost effective solution to you.
Ummm, you might want to take a look at these: nVidia 7300 se - Google Image Search
Old 04-03-2009   #12 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
Re: GPU running very hot at idle.
Hi Ross, I believe your MSI Ms-7301 motherboard is a micro-atx sized board, so any case that supports micro-ATX will be fine to swap to. Most mid sized cases will fit both micro-ATX and ATX sized boards.
That case you linked to should be okay, but make sure you add a 120mm fan to the front. It looks like it only has a single rear 120mm installed.
Whatever case you decide upon should be determined by what your going to use your PC for and whether or not you plan to upgrade the components in the future.
If you plan to leave it as a normal non-overclocked PC, then that sort of case would be sufficient.
However, in the future should you wish to upgrade your components and perhaps over-clock, then a case with more airflow may be a better choice.
Old 04-03-2009   #13 (permalink)
Vista Home Premium x64
Quote  Quote: Originally Posted by johngalt View Post
thanks for correcting me john
however, some SE models don't have cooling
Old 04-05-2009   #14 (permalink)
Windows 7 x64
A friend of mine had one that had passive cooling as well, and it would reach stupid temperatures when playing things like San Andreas.
50% CPU usage at idle...help (please) General Discussion
What is it doing during idle? General Discussion
windows explorer crashes after running idle Vista General
CPU idle Vista performance & maintenance
At idle, no apps running: RAM usage = 851MB Vista General
