Vista - Intel E8400 Temp problem
Old 04-11-2009   #41 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
Re: Intel E8400 Temp problem
Fingers crossed it works for you. Because running at those temps long term is really bad for the CPU
Old 04-11-2009   #42 (permalink)
Windows 7 x64
Well it seems he Intel Speedstep is enabled, which would explain the CPU downclocking when it's idle.
As for the temps, he is using a stock cooler in a place that is generally hot. Having a warm room all the time won't help temps on the PC much. Better cooling will be needed in general.
Old 04-11-2009   #43 (permalink)
Windows 7 Ultimate x64
Quote  Quote: Originally Posted by Everlong18 View Post
Exactly. I read on Intel, they wrote 72.6c temperature. Mine is running at 69-70c. My mobo dosnt allow me to disable Speedstep . Intel DG43NB SUCKS :@
Old 04-12-2009   #44 (permalink)
But not that hot
Quote  Quote: Originally Posted by saeen View Post
Speedstep is not a bad thing. It only downclocks when when it's not under a heavy load.
Old 04-12-2009   #45 (permalink)
See guys, i only applied thermal paste. Only one outlet fan and stock cooler. wow my processor is not faulted
Old 04-12-2009   #46 (permalink)
Windows 7 x64
Much better
Now all you need is a new CPU cooler, add a couple of more case fans (one for input and another exhaust) and you'll be sorted
Old 04-12-2009   #47 (permalink)
It's still a little warm and I bet the temps rise to the 60-70 range under load, but that is a BIG improvement in comparison
Well done
Is it still lagging?
Old 04-13-2009   #48 (permalink)
Not at all lagging any more. Under load it reaches 50-55. I added a fan in front of case. When I'll get a little money, I'll buy a cooler master.
Old 04-13-2009   #49 (permalink)
Good to hear mate
OCing e8400 with asus mobo Overclocking & Cooling
Max overclock with E8400 Overclocking & Cooling
Windows Vista strange settings on temp folder AppData\Local\Temp\1 Vista security
Successful OC e8400 @ 4.00Ghz Overclocking & Cooling
Intel E8400 General Discussion
