| | #11 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: If i set my motherboard to it's native 1333mhz with a CPU that has an 800mhz bus. I don't know how similar the P5Q-EM BIOS is to my P5Q-PRO, but be prepared for being unable to unlink the FSB Strap... ![]() As for juice, depending on your goal, you'll probably just need to up the CPU Voltage/Vcore. When I was running 800mhz RAM @ 849mhz (the link in action), I didn't have to adjust the RAM voltage at all. |
| | #12 (permalink) |
| Vista Ultimate x64 | Re: If i set my motherboard to it's native 1333mhz with a CPU that has an 800mhz bus. I don't know how similar the P5Q-EM BIOS is to my P5Q-PRO, but be prepared for being unable to unlink the FSB Strap... ![]() As for juice, depending on your goal, you'll probably just need to up the CPU Voltage/Vcore. When I was running 800mhz RAM @ 849mhz (the link in action), I didn't have to adjust the RAM voltage at all. Hows the overclocking on the pro version going for you, had any problems with the motherboard? |
| | #13 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: If i set my motherboard to it's native 1333mhz with a CPU that has an 800mhz bus. You can get it to 1 to 1 or other ratio's but it's dependant on what you set the FSB and FSB strap to. ie You don't get much choice ![]() The board overclocks very well but I have had a niggly stability issue since day one. However it's hard to say whether it's the board itself, a faulty CPU or a BIOS setting that is just a little off (user error). If I were to put money on it, I'd say it's the latter as there are some options I haven't tried yet. (there are a lot of options )Personaly if I were to get another asus ddr2 board, it would be the deluxe simply because it has better stock NB cooling and allows more control over the GTL settings. |
| | #14 (permalink) |
| Vista Ultimate x64 | Re: If i set my motherboard to it's native 1333mhz with a CPU that has an 800mhz bus. You can get it to 1 to 1 or other ratio's but it's dependant on what you set the FSB and FSB strap to. ie You don't get much choice ![]() The board overclocks very well but I have had a niggly stability issue since day one. However it's hard to say whether it's the board itself, a faulty CPU or a BIOS setting that is just a little off (user error). If I were to put money on it, I'd say it's the latter as there are some options I haven't tried yet. (there are a lot of options )Personaly if I were to get another asus ddr2 board, it would be the deluxe simply because it has better stock NB cooling and allows more control over the GTL settings. |
| Motherboard fried, new motherboard, oh oh disk driver issues, blue screen rebooty time! | Vista General | |||
| 1066Mhz vs 800Mhz memory ram. | General Discussion | |||
800mhz ram shows as 400mhz | General Discussion | |||
| WOW, no NATIVE x64 antivirus.. | System Security | |||
| Cool 'n' Quiet or stuck at 800Mhz | Vista hardware & devices | |||
