Vista Tutorial - If i set my motherboard to it's native 1333mhz with a CPU that has an 800mhz bus....
Old 04-13-2009   #1 (permalink)
Vista Ultimate x64
Would this overclock all my components on the front side bus? The reason I ask is because if i was to put a CPU in with a rated 1333mhz bus speed for example my FSB would be set at that speed but it would not be overclocking my ram chipset e.t.c they would be at there stock rated values still.
So i'm assuming as 1333mhz is a native preset for my motherboards bus speed I should be able to run at this bus speed without overclocking everything else on the BUS?
Old 04-13-2009   #2 (permalink)
<3 Nvidia
Windows 7 x64
Re: If i set my motherboard to it's native 1333mhz with a CPU that has an 800mhz bus.
You can overclock the FSB without overclocking the RAM, but it will overclock the CPU, like if you put an 800MHz FSB CPU in a 1333MHz mobo the mobo will downclock to 800MHz, so then overclocking this will overclock the CPU, as well.
Old 04-13-2009   #3 (permalink)
Eye know, eye know
Vista Ultimate SP2 x64 : Seven Ultimate x64
On my Asus board, there actually isn't a way to unlink the FSB from the RAM. So any FSB changes have a direct impact on RAM speed
I noticed you have an older Asus board, so it might be something to look out for in the BIOS.
Old 04-13-2009   #4 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by Everlong18 View Post
I have onboard video at the moment & I don't wish to overclock the chipsets either just the CPU.
Just hoping to overclock the CPU by running at 1333mhz native motherboards bus speed while leaving everything else at it's native speed if that makes sense?
Like as if i was running a 1333mhz CPU everything else would still run at native speeds.
The CPU I have has been OC to a 1333mhz bus speed running stable by other people from what ive read via google, but I dont think I can lock the onborad video to OC it up to that FSB.
If I could make it run at 1333mhz like a CPU of that bus speed my onboard video would be running at it's native speed still.
Old 04-13-2009   #5 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by smarteyeball View Post
Just got a new motherboard that has a load of OC options and a much higher FSB than my old one so im looking to get a performance boost from my aging CPU. I will replace the CPU at some point but cash is abit low at the min.
Old 04-13-2009   #6 (permalink)
<3 Nvidia
Windows 7 x64
Well if your CPU is capable of being pushed to a 1333MHz FSB, and you have adequate cooling, then it's up to you if you want to try it. Overclocking the FSB won't overclock your onboard video, and like what Smarty said, may or may not overclock your RAM.
Old 04-13-2009   #7 (permalink)
Vista Ultimate x64
Are you sure about my onboard video not being overclocked aswell? I thought anything on the FSB will be effected when you increase it's speed.
Old 04-13-2009   #8 (permalink)
<3 Nvidia
Windows 7 x64
As far as I know, the onboard video isn't linked to the FSB, it's just controlled by the CPU.
Old 04-13-2009   #9 (permalink)
Eye know, eye know
Yep, onboard will remain untouched.
What board did you get btw?
Old 04-13-2009   #10 (permalink)
Vista Ultimate x64
Asus p5q-em, not the best overclocker at the min tho it should be with all the OC options in the bios. It even allows you to make OC profiles in the bios & save your best configurations. Bios updates have slowly been improving the boards teething problems with the new intel Intel G45 Express chipset. Seems to have problems on all the boards out with this new intel chipset at the min. Just realized i forgot it has a max BUS speed of 1600 MHz. Heres a link to the board with the full specs
ASUS P5Q-EM iG45 Socket 775 onboard VGA 8 channel audio mATX Motherboard - Ebuyer
Won't i need to give some more juice to the chipset if i overclock tho?
Thanks for all the responses by the way people's.
Motherboard fried, new motherboard, oh oh disk driver issues, blue screen rebooty time! Vista General
1066Mhz vs 800Mhz memory ram. General Discussion
Solved 800mhz ram shows as 400mhz General Discussion
WOW, no NATIVE x64 antivirus.. System Security
Cool 'n' Quiet or stuck at 800Mhz Vista hardware & devices
