Vista Tutorial - GPU Overclocking Guide
Old 04-13-2009   #1 (permalink)
Windows Vista Home Premium 64 bit w/ SP1
Desktop GPU Overclocking Guide
Some people are unsure on how to overclock the GPU. Quite frankly, the GPU is the easiest thing to overclock in a system. Lets start from the beginning.
This will void your warranty if you have an ATI video card.
The first thing I recommend is to grab some useful programs and the latest NVIDIA WHQL drivers. The programs I recommend are EVGA Precision 1.7.0 or Rivatuner (for the overclocking/monitoring), GPU-Z 0.3.3 (monitoring/GPU info), and ATItool (artifact testing).
ForceWare 182.50 WHQL DriverProper uninstallation/installation of video drivers (Vista, in XP it should be somewhat similar):
  • Download and install Driver Sweeper or something similar.
  • Right click on computer, click Device Manager (on left)
  • Select your display device (video card), uninstall video device software.
  • Delete driver folder (C:\NVIDIA\WinVista64\1xx.xx)
  • Reboot in safe mode (repeatedly hit F8 during boot sequence).
  • Run Driver Sweeper or your equivalent. Only clean Display driver.
  • Reboot.
  • Download and install your desired driver.
  • Reboot.
When installing new drivers, make sure all anti-virus software is disabled.
EVGA Precision 1.7.0 Download
GPU-Z 0.3.3 Download
ATItool 0.26 Download
Driver Sweeper 1.5.5 Download
For those of you who don't know, artifacts occur when your GPU is overclocked too high and/or your temperatures are too high (but not high enough for a shut down). If you get artifacting right out of the box with good temperatures and you did the proper method of installing new (and different) NVIDIA WHQL drivers, I suggest you RMA your GPU. Make sure your temperatures stay below 105 degrees Celsius, that is the max most cards can handle. It is best to stay below 90 degrees Celsius, artifacts can occur before 105.
For this guide I'll be using my primary video card for example, an EVGA GTX 260 CORE 216 (55nm). This is the vanilla (default) version which came at the factory overclocks.
Factory Settings:
  • Core Clock: 576 mhz
  • Shader Clock:1242 mhz
  • Memory Clock: 999 mhz (1998 mhz effective data rate)
  • Fan Speed: Auto (40%)
Uh oh, we ran into another confusing term here.
Effective data rate? What does that mean? My card was supposed to come with 1998 mhz memory but it is shown as 999 mhz!
High end video cards use double data rate memory, usually GDDR3 or on several ATI cards they use GDDR5 as well. Multiply the memory clock EVGA Precision/GPU-Z shows to get the effective data rate, which is usually what is advertised.
999 mhz x 2 = 1998 mhz
Now onto the overclocking. I open up EVGA Precision 1.6.1, GPU-Z 0.3.3, and ATItool 0.26. My core clock is 576 mhz, shader clock is 1242 mhz, memory clock is 999 mhz just as it should be. Core/shaders are linked and fan speed is auto, or 40%. Notice with EVGA Precision 1.6.1 you can select other video cards to overclock separately. The monitoring graph can be removed from the box and expanded to show additional information. Very useful. Do not enable Apply at startup until you've ensured stability!
http://img11.imageshack.us/img11/9613/defaultzxn.png
By boredgunner at 2009-04-13
Lets get started. Unlink the core/shaders, and set fan speed to manual and raise it a little. You can push the sliders up, or enter a number and it will give you your desired clock speeds. Overclock in small increments, no more than 25 mhz at a time for the core clock. Shader clock should run at least double the core clock so you won't have any issues. Memory clock should be raised in small increments too, no more than 25 mhz. After the first small overclock, select the scan for artifacts feature on ATItool. So first I unlinked core/shaders and set fan speed to 60% (it went to 61% on it's own).
I increased the core clock speed from 576 mhz to 600 mhz, shaders from 1242 mhz to 1280 mhz, and memory clock from 999 mhz to 1025 mhz. Yeah a little more than 25 mhz increments but I've overclocked this card before, I know what it is capable of.
http://img7.imageshack.us/img7/9606/overclock1.png
Run ATItool for a little while (several minutes) and see if you run into any artifacts. I didn't, so lets move on.
Lets bump it up to GTX 260 SC speeds, 626/1350/1053 (core/shaders/memory). I'm making pretty large heaps because I've overclocked this card before.
http://img9.imageshack.us/img9/3752/overclock2.png
Run ATItool. Still success, lets move on.
Bumped up to FTW speeds. No errors yet.
http://img7.imageshack.us/img7/9453/overclock3.png
Run ATItool. I ramped the fan speed up to 80% to keep the temperatures down. It got quite noisy, but I don't really care. Still success, lets move on.
Lets push a little bit further, 684/1476/1190.
http://img13.imageshack.us/img13/8858/overclock4.png
I ran into an error. What do I do?
Lower the speeds a little bit. If you get the nvlddmkm stopped responding and has recovered error, try lowering the memory clock first. If it still persists, lower the core. If it still persists, lower the shader clock too. Lower them to the last successful clock you had them at, and move forward again a little bit more. Sometimes you can get a BSOD from the same error. These blue screens are pretty detailed and usually say nvlddmkm stopped responding and has failed to recover or something along the lines of that. Follow the same procedure.
I can't overclock as high as others who have the same card. Why is this?
Not all cards are the same, some overclock further than others. Water cooling your GPU can help you reach higher speeds.
How much does GPU overclocking affect performance?
In games, the difference isn't that noticeable unless you reach a very high overclock. In GPU heavy benchmarks such as 3DMark Vantage you'll get a nice increase in your GPU score and even your overall score if you've achieved a decent overclock.
EVGA offers SC, SSC, and FTW models. What is the difference?
These are factory overclocked, guaranteed to work above the default speeds. In my opinion the SC/SSC models aren't worth it when there is a FTW model for that card, from what I've read these are the parts that fail to reach the FTW spec but I'm not too sure on this. The FTW cards are priced very high but they also have very nice overclocks on them. Same goes for the SSC on cards that have no FTW model. I passed the FTW speed on my GTX 260, but failed to reach the EVGA SSC speed on my PNY 9600GT (9600GT SSC comes at 740/1836/975).
I've ran into my max overclock. When you do, you can upload a validation file on GPU-Z for bragging rights
Here is the validation for my GTX 260. 19% increase across the board. Not bad.
techPowerUp GPU-Z Validation cun93
One for my PhysX Processing Unit too, 9600GT. 11% increase on the core/shaders, 6% on the memory. Disappointed, but oh well.
techPowerUp GPU-Z Validation 2qfha
Final Settings:
  • Core Clock: 684 mhz
  • Shader Clock: 1476 mhz
  • Memory Clock: 1190 mhz (2380 mhz effective data rate)
  • Fan Speed: 80%
Last edited by boredgunner; 04-18-2009 at 11:50 AM.. Reason: Images converted to URLs until reduced in size
Old 04-13-2009   #2 (permalink)
Eye know, eye know
Vista Ultimate SP2 x64 : Seven Ultimate x64
Re: GPU Overclocking Guide
Great work mate
But for future reference, try using the paperclip attachment to upload pics. This avoids the massive browser window stretching with large images.
Old 04-13-2009   #3 (permalink)
DNPNWO
Vista Ultimate X64 SP2
ATITool will only work on Windows 2000/XP/2003 (64 bit versions are supported).
doesnt look like this is x64 vista supported, and what about mobility cards?
Old 04-13-2009   #4 (permalink)
I have Vista x64 and it works fine. As for mobility cards, lets see if someone comes up with a thread for that
Old 04-14-2009   #5 (permalink)
know-it-all
Vista business x64
It says the EVGA Precision tool is for EVGA cards only.
I have an ASUS 9800GTX+, what tool should I use to overclock my GPU then?
EDIT: nvm, apparently it works for any card lol.
Will play around a bit with it right now and post the results later if I succeed a nice stable OC
Old 04-14-2009   #6 (permalink)
Gamer
x64 Vista Ultimate
Nice guide, I'll poke around with your method when I get home
Old 04-14-2009   #7 (permalink)
<3 Nvidia
Windows 7 x64
It's a nice guide. Explains everything well.
When I get chance, I could add a stage for people who want to go a step further, by flashing their graphic card BIOS and adding the new one with their overclocking and fan speeds profile on, so the card keeps the new speeds as default, or you can add it yourself if you'd prefer to research it
Though I wouldn't recommend it, unless you really know what you're doing.
Old 04-14-2009   #8 (permalink)
know-it-all
Vista business x64
I played around a bit with overclocking my GPU but I wasn't able to OC it more than 10% before I started to get graphical errors in ATItool so I decided to just keep it running at stock speed.. which has always worked fine for me =)
Old 04-15-2009   #9 (permalink)
im coming for cake
ultimate 64 SP1
Great work boredgunner.........
SK
Ultimate Core i7 Overclocking Guide Overclocking & Cooling
Overclocking my rig... Overclocking & Cooling
Intel Overclocking Guide Overclocking & Cooling
overclocking ??? Overclocking & Cooling
Overclocking Vista performance & maintenance
