| | #31 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Which Rig for Best Airflow??? I hate those plastic clips. As you've discovered, they're far to easy to break. I don't think it would have too much of negative impact on your temps, if any. I use Everest Ultimate which I got straight from their site: Lavalys - Comprehensive IT Security and Management |
| | #32 (permalink) |
| Vista Home Premium 64bit | Re: Which Rig for Best Airflow??? Thx Smarteyeball, I'm at work right now but I'll connect via Logmein.com and download that version. I want to run it now while I'm at work and see what it heats up to. Thanks for all of your help Smarteyeball. |
| | #33 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Which Rig for Best Airflow??? No worries mate. I'm interested see how it works out for you |
| Corsair Dominator Airflow Fan | Overclocking & Cooling | |||
| Fan Setup for Best Airflow??? | Overclocking & Cooling | |||
