| You Will Service..Us | Core i7 975 XE Breaks 5 GHz Barrier, With Air Cooling Quote: Intel's newest high-end processor, the Core i7 975 Extreme Edition is gearing up for launch later this year, on course of which, it already passed a milestone. Xtreme Systems Forums member PcCI2iminal scored one with overclocking a Core i7 975 XE D0 stepping chip part the 5 GHz mark, 5015 MHz to be precise using only air cooling for the processor, with an ambient temperature of 20 °C as claimed by the overclocker. |
| ATI\AMD <3 Jesus..<3 | Re: Core i7 975 XE Breaks 5 GHz Barrier, With Air Cooling hm........... he must have had one heck of a air cooler...... i bet the phenom II can do the same |
| <3 Nvidia | Re: Core i7 975 XE Breaks 5 GHz Barrier, With Air Cooling Highest OC I've seen a Phenom II on air is around 4GHz at the moment. A nice OC though on the 975. Hope it's released soon, so then Intel can lower their prices on other CPUs and I can upgrade |
| ATI\AMD <3 Jesus..<3 | Re: Core i7 975 XE Breaks 5 GHz Barrier, With Air Cooling hm... i was talking about the 955..... haven't seen waht it can do yet :P haha but i'm not gonna give a grand for that chip.... i'd pay at most $400 even then thats a little much |
| I Click Home To Much | Re: Core i7 975 XE Breaks 5 GHz Barrier, With Air Cooling yes he did that with a simple TRUE cooler. there is another user in XS that has the D0 revision of the 920, and he was able to get to 5.3 Ghz with simple water cooling + some ice, with a Koolance CPU Block and a Koolance pump.. that is impressive as well. |
| | #6 (permalink) |
| ATI\AMD <3 Jesus..<3 | Re: Core i7 975 XE Breaks 5 GHz Barrier, With Air Cooling hmm... well if someone will give me a phenom II i'll be glad to try and take it to 5ghz on air |
| Re: Language barrier using remote assistant | Live Messenger | |||
| whoever is using a quad core q6600 and generic stock cooling that came with cpu p | Overclocking & Cooling | |||
| Vista freezes solid on AMD dual core, single core ok | Vista hardware & devices | |||
| Intel duel core question with Vista 2nd core not showing being used Help? | Vista General | |||
| Shrinking volume barrier | Vista General | |||
