Vista - How does vista use multicores
Old 05-29-2009   #11 (permalink)
Vista Ultimate SP1 x64
Re: How does vista use multicores
Its defiantly worth it as ive found a lot of my games can actually use 4 cores. Also wont break the bank trying to cool it as well which is great news.
think ill wait until summer is over b4 i start changing my pc, i was cleaning some of the dust out of the case and due to the heat was sweating like mad. Made a right mess of the shiny finish.
Will yorkfields still be widely available by that time?
Old 05-29-2009   #12 (permalink)
Windows 7 x64
Most likely they will. I'm planning to upgrade to a Q9550 or a Q9650 around October/November to buy myself something for my birthday
There's apparently going to be a price drop on all Intel CPUs as well when the i7 975 is released.
Old 05-29-2009   #13 (permalink)
price drop would be cool, might even be able to go for q9650.
