| | #11 (permalink) |
| Vista x86 Home Premium | Re: The Best way to overclock on Vista Howdy, I've managed to get my CPU stable (After running 1hr,31min Stress test with Prime95) at just under 2.5GHz, if i increase the FSB anymore windows boots then Bluescreens. Ive included Screenshots of the CPU Idle (after 5 mins) and then one after the stress test. The temps seem to be good, i will run the test for longer time soon, just to double check, is there anything else you reccomend i do? |
| | #12 (permalink) |
| Vista Ultimate x64, SP2 | Re: The Best way to overclock on Vista Did you say that you cant adjust the multiplier ?, if you cant then it wont matter, thats a nice o/c with really good temps. when you get the other stick of ram you can have a go at o/c'ing the memory, glad you got there. Good luck. |
| | #13 (permalink) |
| Vista x86 Home Premium | Re: The Best way to overclock on Vista I can't increase only decrease, i believe ive read the term is 'Half-Locked'. I'm happy with the speeds and the temps. You notice the improvement via the Processor not maxing out near as much, almost constant when at 1.8. I will get the RAM next week. Im still on the budget, but can you reccomend any Suitable RAM, In MY system i use OCZ Platinum range - but to be honest i only really bought them because they looked very pretty I know the timings are good but havent exactly read into to them much. But because im not really met with problems i never bother to.The RAM in the system is only generic tat i got given. So im sure a replacent would work some magic. Thank you very much BTW, you have been such a great help. |
| | #14 (permalink) |
| Vista Ultimate x64, SP2 | Re: The Best way to overclock on Vista Take a look at my system specs, i cant fault this ram in any way, if you google it there are some good deals out there. Thanks, it has been good fun. |
| I7 920 overclock | Overclocking & Cooling | |||
| can overclock gpu | Overclocking & Cooling | |||
| To Overclock or Not Overclock? | Overclocking & Cooling | |||
| Should I Overclock? | Overclocking & Cooling | |||
| Overclocking problems, Oc fine in XP, but the smallest overclock in vista = freeze | Overclocking & Cooling | |||
