| | #31 (permalink) |
| Lost in my own World | Re: Can a PSU cause heat problems? i actually ran one for 3 years before the internet. i miss those days some times. |
| | #32 (permalink) |
| Member | Re: Can a PSU cause heat problems? I never changed voltage, didn't know you really could. Heres a link to a picture of speedfan, it lists the voltages and temps. I hope one of you can spot a knot with this. At this point I don't really know what to ask or where to go. We did the grain of rice size method, then put it on the cpu and took it off and looked. It spread just like we seen it on the few videos we watched. Imageshack - picsb *edit* Forgot the link lol. |
| | #33 (permalink) |
| Lost in my own World | Re: Can a PSU cause heat problems? my wife's laptop runs hotter than that. not sure will look into it. oops old pic running at 73 at the moment |
| | #34 (permalink) |
| Gamerholic | Re: Can a PSU cause heat problems? Hello Exidium, Are these temps idle temps or load temps ?, also what is the ambient temp at your location ?. One thing i would check is that there is enough pressure being applied to the heatsink, i.e. it's being pushed down hard on to the CPU, in no way should it be loose. |
| | #35 (permalink) |
| Gamerholic | Re: Can a PSU cause heat problems? You brought back happy memories with the mention of the K6 |
| | #36 (permalink) |
| Member | Re: Can a PSU cause heat problems? Those were idle temps, The heatsink is mounted and really sturdy. Ambient temperature is 69f. |
| | #37 (permalink) |
| Gamerholic | Re: Can a PSU cause heat problems? The max temp for your CPU is 71.4C, if under load it stays on or around 60C then i would go with that. Hope this helps, good luck. BX80580Q8200 - Intel Core 2 Quad Q8200, Yorkfield Core, S775, 2.33GHz, 1333MHz, 4MB L2 Cache, 7x, 95W, Retail - Scan.co.uk |
| | #38 (permalink) |
| Lost in my own World | Re: Can a PSU cause heat problems? Wow that is pretty high. but i guess mine is max temp of 73c AMD Processors for Desktops: AMD Phenomâ„¢, AMD Athlonâ„¢ FX, AMD Athlonâ„¢ X2 Dual-Core, AMD Athlonâ„¢, and AMD Sempronâ„¢ Processor |
| Heat issues with amd!! | Vista performance & maintenance | |||
| A heat problem or CPU | Vista General | |||
| Heat | Vista hardware & devices | |||
| Testing System Heat (GPU & HD) | Vista hardware & devices | |||
