| | #11 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's ok thanks |
| | #12 (permalink) |
| Gamerholic | Re: Laptop MAJOR heat issue's Always a pleasure speaking to you. |
| | #13 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's same |
| | #14 (permalink) |
| Member | Re: Laptop MAJOR heat issue's I believe laptop users can't use fan speed or any other type of fan control is because the fan is linked to the acpi, not the GPU or CPU temp settings. I have a 2.2ghz dual core amd processor and It use to give me a heart attack, but now the temps don't scare me as much. pic she can get pretty toasty, maxed at 90c once |
| | #15 (permalink) |
| CCNA | Re: Laptop MAJOR heat issue's Hi fadedrs, Use a docking station and it will really help reduce such high temps. |
| | #16 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's |
| | #17 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's Here are more accurate temps. still normal for a laptop? sorry this is my first laptop and it never used to get this hot. i know they make the laptop cpu's to run in a hotter enviroment, but it still seems hot. |
| | #18 (permalink) |
| Nvidia and Intel... | Re: Laptop MAJOR heat issue's I bought my mom a 35$ targus dual 90mm fan laptop dock and it got her toshiba, AMD turion X2-64 from 62c idle to 51c-48c idle. |
| | #19 (permalink) |
| Member | Re: Laptop MAJOR heat issue's by the way, what's a docking station? |
| | #20 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's by the way, what's a docking station? a docking station would be the first pic, i think what he meant to say was a cooling pad which is the second pic. |
| Major Problems with Laptop (Vista) | General Discussion | |||
| Issue's with adding more ram. | General Discussion | |||
| Laptop SigmaTel C-Major Audio(Headphone jack does not work) speake | Vista hardware & devices | |||
