Vista - Laptop MAJOR heat issue's
Old 08-12-2009   #21 (permalink)
Vista Home Premium 32bit
Re: Laptop MAJOR heat issue's
if its idle. then u kinda in a big trouble man. that's pretty hot! i mean your core temp. hehe. i've tried using these chilling pad and stuff. doesn't give much benefit actually. only drop around 2-3 degrees. better just buy some beers and use the bottle cap for the gap beneath ur notebook.
Major Problems with Laptop (Vista) General Discussion
Issue's with adding more ram. General Discussion
Laptop SigmaTel C-Major Audio(Headphone jack does not work) speake Vista hardware & devices
