| Lost in my own World | Laptop MAJOR heat issue's As you can see my wife's laptop is having major heat issue's that is low for the temps lately, had it off for over two hours rebooted and it was at 120 it has been sitting around 150 - 180 lately, not sure what it normally sits at but my desktop sit around 90. I have sprayed out the fan ports, removed the pcmia slot holder, going to check the bios in a min for the auto speed fan setting (but i can't see the rpm of the fan anyway). ok checked the bios no settings in there for the fan. any other ideas? Last edited by fadedrs; 06-26-2009 at 02:57 AM.. |
| Gamerholic | Re: Laptop MAJOR heat issue's Hello fadedrs, Thats around the 70C mark, not bad for a laptop i would have thought. If your concerned about it get a laptop cooler, but i would say that temp is not too toasty lol. |
| Lost in my own World | Re: Laptop MAJOR heat issue's thanks stoney, i though it was high. but i guess not. what are the normal operating temps for laptops? |
| Gamerholic | Re: Laptop MAJOR heat issue's They tend to hover around the 60C to 65C mark, although a mate of mine has had one running at 75C to 80C for about 18 months. Keeps him warm in the winter lol. I suppose the ambient temp could have a lot to do with it. |
| Lost in my own World | Re: Laptop MAJOR heat issue's thought maybe there was some thing wrong. is there no fan on the cpu or what? also why does speedfan say nothing about the fan / fans for the laptop? just not supported by the mobo or what? |
| | #6 (permalink) |
| Gamerholic | Re: Laptop MAJOR heat issue's I noticed that, maybe they (SpeedFan) dont support them, may be worth looking in to though. Can you hear the fan working ?, it must be or you would have been dialing 911 by now. |
| | #7 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's yeah i can hear the fan and can feel it exhausting heat out the back of the laptop. |
| | #8 (permalink) |
| Gamerholic | Re: Laptop MAJOR heat issue's Thats ok then. Glad all is well. |
| | #9 (permalink) |
| Lost in my own World | Re: Laptop MAJOR heat issue's yeah just thought the temps were high. |
| | #10 (permalink) |
| Gamerholic | Re: Laptop MAJOR heat issue's You would need to check, but from memory i think the max safe temp is around 85C +/- 5C |
| Major Problems with Laptop (Vista) | General Discussion | |||
| Issue's with adding more ram. | General Discussion | |||
| Laptop SigmaTel C-Major Audio(Headphone jack does not work) speake | Vista hardware & devices | |||
