How to disable auto shutdown due to overheating?
  1. #1
    Newbie
    Vista Home Premium, 64 bit
    Local Time: 05:35 AM
    My Gateway LX6810-01 has a plethora of issues which has lead to my decision to replace it. Since my new machine won't arrive for a few weeks, I'm stuck using this one till it does. I've had issues with overheating and the machine shuts down, in as little as 5-10 minutes of doing anything more graphically challenging than checking my email or writing this post.
    I want to disable the auto shutdown feature so I can actually watch an entire movie, or perhaps even play a game. Since I dont really care about damaging the machine with a new one on the way, I just need the most effective way to do this. I've searched through my BIOS settings and haven't found anything relating to overheating, or temperatures. If someone knows of maybe a hidden, or "locked" BIOS feature, or one I'm missing, or even a solution with software, or in Vista, that would be great.
    Again, just wanted to say I'm not worried about damage to the machine, I just need it to stop shutting down on me when it gets alittle warm.
  2. #2
    skunksmash's Avatar
    im coming for cake
    norfolk
    ultimate 64 SP1
    Local Time: 09:35 AM
    england uk essex
    Re: How to disable auto shutdown due to overheating?
    Quote Originally Posted by Kenn213 View Post
    I want to disable the auto shutdown feature so I can actually watch an entire movie, or perhaps even play a game. Since I dont really care about damaging the machine with a new one on the way, I just need the most effective way to do this. I've searched through my BIOS settings and haven't found anything relating to overheating, or temperatures. If someone knows of maybe a hidden, or "locked" BIOS feature, or one I'm missing, or even a solution in Vista, or with software would be great.
    as far as im aware, there is no option to disable the auto shutdown..... its hardwired into the board, if your rigs overheating there is no option which will allow you to fry your components..
    the reason it cuts out is b/c 1 or more components has reached its thermal threshold & simply cant function...
    maybe you could look at the fan config within your case, what knid of setup are you currently running..??
    SK
  3. #3
    stoneys-nutz's Avatar
    Gamerholic
    Wale's
    Vista Ultimate x64, SP2. XP Pro x64 SP3.
    Local Time: 10:35 AM
    uk uk scotland
    Hello Kenn213,
    Have you tried cleaning out the inside and making sure all the vents are clear, and the fans are working ?, you may get it to run cooler.
    Good luck and post your result's, thanks.
  4. #4
    Newbie
    Vista Home Premium 64bit
    I had the same problem, my MPC was running too hot at 102 C - I installed 2 extra internal fans and so far so good - stopped shutting down. Good luck.
  5. #5
    truthkid's Avatar
    Tactless SOB
    Tikrit, Iraq
    Home Premium X64, not impressed with W7 RC yet...
    Local Time: 12:35 PM
    usa us new york
    Who's to say if you disabled auto shutdown, your computer wouldn't be completely dead before the movie is over?
How to disable auto shutdown due to overheating? problems?
Auto log-off after 10 minutes - How do I disable? Johanna.Nes Vista General 6 03 Dec 2009
how to disable auto reply Paul Vista mail 4 09 Sep 2009
HELP - How do I disable auto logon in Vista anthonyofsd General Discussion 1 29 May 2009
Blue screen after shutdown - auto reboot Render78 Vista General 2 14 Apr 2009
Auto Restart After Shutdown izaaco Vista General 1 11 Feb 2008
