| Vista Ultimate 32bit, 7 Ultimate x64 | Max overclock with E8400 Hi guys, I have an Core 2 duo E8400 @ 4GHz and i'm wondering what is the max speed it can be over-clocked to. |
| Vista Ultimate x64, SP2 | Re: Max overclock with E8400 At 4Ghz you are just about there. |
| Windows vista ultimate (64bit) | Re: Max overclock with E8400 I think the maximum is 4.6GHZ |
| Vista Ultimate x64, SP2 | Re: Max overclock with E8400 I dont think i would want to run one of those at 4.6Ghz on stock air, although thats just a personal observation. Of course you can go higher than 4Ghz, but the life of the CPU will be decreased, just the increase in voltage alone would be enough to do that, follow the link and take a read http://www.overclockersclub.com/reviews/intel_e8400/ Last edited by stoneys-nutz; 07-10-2009 at 05:39 AM.. |
| Vista Home Premium 64bit SP2 | Re: Max overclock with E8400 there is no maximum its all dependant on your particular chip and hardware setup |
| OCing e8400 with asus mobo | Overclocking & Cooling | |||
| Successful OC e8400 @ 4.00Ghz | Overclocking & Cooling | |||
| Intel E8400 Temp problem | Overclocking & Cooling | |||
| help OC'ing E8400 with ASUS Mobo | Overclocking & Cooling | |||
| Intel E8400 | General Discussion | |||
