Vista - Help underclocking plz :)
Old 08-09-2009   #11 (permalink)
Windows Vista Home Premium 32bit
Re: Help underclocking plz :)
I've tried making the Maximum processor state 50%, then 20%, then even 5%. It doesn't change anything. IT IS USELESS!
Old 08-10-2009   #12 (permalink)
Vista Ultimate x64 SP1
Setting the maximum processor state does not affect the clock speeds of your CPU. It is only a soft limit on the CPU utilisation.
You must use the BIOS (can do it through Windows but I wouldn't) to underclock your computer.
I am just curious, why are you underclocking your CPU? Is it a laptop?
Underclocking Athlon64 X2 6000+ (desktop board) Overclocking & Cooling
Underclocking an X1650 Pro in Vista 64? Graphic cards
