Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Vista - Help underclocking plz :)
07-21-2009   #1 (permalink)
Vista Home Premium 32bit
Hi guys i own a Hp Pavilion tx2000 Notebook Pc. My processor is a AMD Turion(tm)
64 X2 Mobile Technology TL-62 2.10GHz with Vista 32-bit Operating System. Any idea how can i Underclock my Cpu ?
07-21-2009   #2 (permalink)
Vista Ultimate x64, SP2. XP Pro x64 SP3.
Wale's
Re: Help underclocking plz :)
Hello Chandi,
You may find that your Bios is locked and not able to be altered.
Can i ask why you would want to underclock you CPU ?.
07-21-2009   #3 (permalink)
Because i want to lower the temperature i wanna keep my pc cool down. but is there a way i can unlock that in my Bio Settings ?
07-21-2009   #4 (permalink)
Windows 7 Ultimate X64, Vista Ultimate X64, XP Pro X64, Vista Home Premium X86
Maple Grove, MN
your temps wont go down if you overclock, they might go up a little but.
07-21-2009   #5 (permalink)
im wanna Under not Overclock ^.^
07-21-2009   #6 (permalink)
Wale's
If you want to underclock you will need to go into the Bios, but i doubt you can change anything because it may be all locked. What are your temps ?.
Laptops may feel hot but the temps are not always critical.
07-21-2009   #7 (permalink)
temps are good lol. but i rlly wanna uc my cpu
07-21-2009   #8 (permalink)
Wale's
I'm afraid your not going to be able to, go in to the Bios and you will see that it is locked.
07-21-2009   #9 (permalink)
Maple Grove, MN
sorry misread it,
yeah HP locks there bios always.
07-22-2009   #10 (permalink)
7 Ultimate x64 : Vista x86 VM
Australia
In the power management options, you can specify "processor state" usage for either battery or plugged in. Try limiting the CPU to 50% to see if it impacts on your temps.
Help underclocking plz :) problems?
Similar topics to: Help underclocking plz :)
Underclocking Athlon64 X2 6000+ (desktop board) Overclocking & Cooling
Underclocking an X1650 Pro in Vista 64? Graphic cards
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
