Vista - Upgrade to Liquid
Old 08-03-2009   #1 (permalink)
Vista Ultimate x64
Upgrade to Liquid
Allo, first post on this forum, been lurking quite a while though.
Finally it's bugged me enough to want help, as I'm not sure where to turn for this.
Right now I have 2 9800GTX+'s in SLi in my rig, along with a Q6600 on an MSI P7N SLI Platinum. I love this system to death, but dear god do the GPUs run hot.
Right now, running FFXI at highest settings (minimized), it's sitting at 64C. I'd love to knock them down a bit, and water cooling seems to be the best option, but I have no idea where to even start.
I'm not sure if these cards even support a cooling block (especially since it's in SLI mode). Right now there's an EVGA cooler on them (stock), and it's absolutely worthless. Not only are the cards smoking hot, but my room is the hottest room in the house. I'm not liking it at all on 90F days, lol.
Even during the winter my room gets toasty enough that I open the window to let some cold air in.
I guess my real question is, what am I best off doing? I was looking at the Koolance Exos-2.5. Supposedly it cools 1000W worth of heat. I'm not sure if this is overkill, as I plan to upgrade one day (hopefully to i7, GTX2xxx's)
Well, I hope this wasn't too little/much information, I'm just seriously confused.
Also, so I don't forget once that is all cleared up.
How should I go about the route to adequately cool all the neccessary components? (Doesn't need to be answered right away, just for my own reference, but if someone wants to answer feel free lol).
Thanks again =)
Old 08-03-2009   #2 (permalink)
Vista Ultimate x64 SP1
Re: Upgrade to Liquid
Quote  Quote: Originally Posted by KtotheFC View Post
64C isn't hot at all. Newer Nvidia cards will run upward of 95C before you run into any real problems.
My GTX285 peaks at about 85C-86C and it is still going fine.
How hot do they get when they are fully loaded?
Old 08-03-2009   #3 (permalink)
Vista Ultimate x64
Right now they're on auto, 51% fan speed, 61C & 62C
Old 08-03-2009   #4 (permalink)
Oh I do apologise, only after reading you post again did I see that you are new here so welcome to Vista Forums, I hope you enjoy your time here.
You are definitely safe at those temperatures. The fans will increase in RPM when the GPU is getting hotter so I wouldn't worry about it.
Old 08-03-2009   #5 (permalink)
Vista Ultimate x64
Thanks for the welcome =)
Fully loaded, I haven't tested in a while, I never really see them hit 70C or so during normal gaming though.
I usually leave them on at 100% speed, but they throw out some massive heat into my room so I've been trying to keep it lower lol.
Old 08-04-2009   #6 (permalink)
As I said, you are safe well into the 80s and even 90s with those GPUs.
Just leave the auto fan controller to do its work, it will make gaming better because you won't have the fans producing so much noise and your room shouldn't heat up as fast.
I find that with my GTX285 the fan doesn't move from 40% until 65-70C and I can only hear the fan when the GPU hits 80C+ (and it only gets that hot in FurMark).
According to Nvidia the 9800GTX+ have a max temp of 105C, the card would probably start throttling in the mid to late 90s but I am yet to see any of my GPUs even go past 86C.
Old 08-04-2009   #7 (permalink)
Vista Ultimate x64, SP2
Hello KtotheFC,
I had two BFG 8800 ultra's in SLI, that ran at 76.C under load, and i always thought that was good.
Pinnacle Liquid Software
[ANN] Liquid XML Studio 2009 SP1 Released .NET General
ANN: Liquid Technologies Releases New Freeware XML Studio AndSilverlight Code Generator .NET General
Soak It to Me: Inside Liquid-Suspended Gaming PC Overclocking & Cooling
logon screen spilt liquid Vista General
