CPU temperatures
  1. #1
    Sydney, Australia
    Vista Ultimate 64-bit
    Local Time: 04:52 PM
    australia au new south wales
    CPU temperatures
    Hey guys,
    My (stock speed) Intel Q9550 @2.83Ghz is running at temps of 105 degrees Celcius or 221 degrees farenheight (for those not from my country)
    I dont think this is normal, am i right?
    I think this is the sole reason for my constant computer freezes?
    Im guessing Im right and I have to get a new CPU fan/heatsink and some top quality thermal paste.
    Any suggestions for socket 775? I want the absolute best fan solution available with the best thermal paste known...
  2. #2
    smarteyeball's Avatar
    Eye know, eye know
    Australia
    7 Ultimate x64 : Vista x86 VM :W8 RP x64
    australia au queensland
    Re: CPU temperatures
    What are you using to monitor those temps? Because that is insanely high
    No, those temps are far from normal. I'd check that your HSF is properley attached. ie all the pins are firmly pushed in.
    Some good CPU Heatsinks are the TRUE 120mm, or either the Noctua NH-U12P or NH-C12P. There are a few others that are good too.
  3. #3
    Sydney, Australia
      Thread Starter
    Im using Nvidia System Monitor, Im not too sure if this is correct as you stated, because those temps are far too high. Im putting my desk fan on with my case open and so far so good, but these temps are way too high (I dont think they are accurate). I went into the bios, but I dont know its pretty vague (and my NB and CPU wont be as hot at startup anyway)
    But I am concerned. Because I've been getting system freezes for a long time now
  4. #4
    Crispy2007's Avatar
    64 |3!T G33|<
    Aus, QLD
    Windows 7 Ultimate x64 (Build 6.1.7600.16385)
    Run the computer till the temp getup to the highest then hit the reset button go strate into the bios and have a look at the temps an see if they are right.
  5. #5
    Eye know, eye know
    Australia
    Personally, I wouldn't trust certain monitors like NSM etc.
    If the BIOS is showing high temps, even after only being on for few a minutes from a cold start, it's a cause for concern.
    Try a few different (bmore accurate) montoring apps and see if they are all the/similar temp wise:
    Download Real Temp 3.30 RC12 / 3.00 - A temperature monitoring program - Softpedia
    SpeedFan - Access temperature sensor in your computer
    http://www.cpuid.com/hwmonitor.php
    Lavalys - Comprehensive IT Security and Management
    If the CPU HSF is correctly installed and it's still showing outrageous temps, check to see if there is a BIOS update available for your mobo.
    It could just be a bug with the sensors, but the fact that the PC is freezing tends to suggest otherwise.
  6. #6
    skunksmash's Avatar
    im coming for cake
    norfolk
    ultimate 64 SP1
    Local Time: 06:52 AM
    england uk essex
    Quote Originally Posted by alexdagr8est View Post
    Hey guys,
    that's a 100% sensor malfunction.........., the Q9550 wont take 105c, in reality it would cut out just above 70c & BSOD.
    as Smarty has stated try some other monitoring apps
    the PC lock up is quite worrying though, try the apps listed above & get back to us...??
  7. #7
    Blackhawk7188's Avatar
    Senior Member
    Reading PA
    Vista Home Premium x64 SP2/Ubuntu 10.04 LTS/XP Home Virtual PC 2007
    Local Time: 02:52 AM
    usa us pennsylvania
    Were you cooking eggs or somthing on that thing? I mean 212 Degrees will boil water. If you are running that either your heatsink isnt connceted or its just not registering the temperature correctly. You should shut that thing off before it breaks on you.
  8. #8
    Eye know, eye know
    Australia
    I think it might have broke
  9. #9
    Senior Member
    Reading PA
    usa us pennsylvania
    That doesnt sound good....any idea what may have broke?
  10. #10
    panais's Avatar
    Senior Member
    Windows 7 Ultimate 64bit
    Local Time: 08:52 AM
    TemperaturS
    I also need some answers...
    TemperatureS
Page 1 of 2 12 LastLast
CPU temperatures problems?
TemperatureS panais Overclocking & Cooling 9 18 Sep 2009
High temperatures due to OCing amigo max Overclocking & Cooling 3 29 Jun 2009
Fresh windows vista ultimate x64 install <CPU and GPU temperatures screwed> Exidium General Discussion 9 23 Jun 2009
Vista; Failure to read S.M.A.R.T. temperatures VistaHelpRequested Vista General 4 22 Jul 2008
Where Linux Beats Vista : CPU Temperatures - ACPI Thermal Zones Robert wilkens Vista General 43 05 Dec 2006
