Talk about hot...
I was using the Dv7 doing 3D modeling with 2 models at the same time on my screen. I checked the temps at the time....87 Degrees Celegrade!!! I was like no way this is happening. I am assuming that this is bad...but does anyone have any suggestions on how to possibly cool this down or is it acceptable at times to have this happen when I am modeling? I need to get some canned air to clean it out some so that may make a difference.
Thanks in advance.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM
    Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Full Keyboard with numpad
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010.
    Also I love to watch HD movies using the HDMI output(Netflix).
    Linked to my Xbox 360 for Windows Media Center
    3 USB ports + USB/eSata
    HP Remote for Windows Media Center and Quickplay
    Internal Dual Layer DVD+/-RW
    External HP Lightscribe Dual Layer DVD+/-RW
    HP Webcam and Microphone
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
I have tried looking at stores and I am yet to find a cooler for a 17" laptop. They are usually the size for 14.1" laptops and mine is just way to big for one of those.
    17" Laptop Screen
Hi Blackhawk7188,
I flog a similar HP laptop to yours.
I have mine raised at the back to allow for better air circulation.
Have you turned your laptop over to clear the grot away from the air intake area?
    1440 x 900
    SPECS.
    Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device
    Drive 2. [ All as above.]
    CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Hello Blackhawk7188,
What did you use to measure the temperature ?.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
I use Core Temp x64 Edition. And I just cleaned it out last night, now it just comes down to when I need to model next time.
    17" Laptop Screen
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
