Vista - Are you a Sucker or a Blower.
Old 08-25-2009   #11 (permalink)
Xp-Vista-7
1 x 120mm suck
1 x 120mm blow
need more fans...
Old 08-25-2009   #12 (permalink)
Vista Home Premium 64bit SP2
Quote  Quote: Originally Posted by Martee View Post
Quote  Quote: Originally Posted by JMH View Post
My laptop is a very quiet sucker & blower.
Mine is two fun blower.
You could fry an egg on my wifes laptop , its always been like that , i wouldnt dare check the temps , it works so i just assume its fine .......... it blows ALL the time ha ha probably something to do with the fact it was switched on when we got it 10 months ago and its NEVER been switched off since
Old 08-25-2009   #13 (permalink)
ultimate 64 SP1
Quote  Quote: Originally Posted by archie123 View Post
if you suck more air in than your blowing out or vice versa it creates a volume of trapped air that circulates around the case getting hotter and hotter (to a point obviously im not saying it gets to 100 degrees or out )
you need a good balance of "suck" and "blow" this can also be balanced out with vents or small holes in the case sides as are often present in new cases.
the differance between balanced and unbalanced cooling can be small but as your asking...........
sounds logical......
but where dust is concerned a ''positive'' pressure is preferred (more in than out).
Old 08-25-2009   #14 (permalink)
Vista Home Premium 32bit and Ubuntu 9.10 32bit
ok in mine there are 3x 120mm intakes 2x 140mm outs and 1x 120 out.... and then whichever way the psu fan blows haha....... i think the last 120 is out anyway...... it might be intake...... i forget haha
Old 08-25-2009   #15 (permalink)
Vista Ultimate x64 sp2, Solaris x64
Ten months non-stop. Did you clean it? If not it's the right time.
Old 08-25-2009   #16 (permalink)
yeah i hosed it down with cold water , got it right inside made sure it cleaned all the components properly then gave it a soapy bath..............its not been the same since tbh dunno why
Old 08-25-2009   #17 (permalink)
ultimate 64 SP1
it was probably the sponge you used, the soft material causes static.....lol
Old 08-25-2009   #18 (permalink)
High pressure hot water is the best. Highly recommend it
Old 08-25-2009   #19 (permalink)
Vista Ultimate 64-bit, SP2
I believe putting a laptop in the dishwasher on a gentle cycle does a good job.The dying cycle works wonders. [I haven't tried it yet.]
Old 08-27-2009   #20 (permalink)
Re: Are you a Sucker or a Blower.
well, my psu (with 120mm fan) 295 co-op and 9800 are all blowers along with a rear 120mm and a top 250mm
as for suckers, I have a front 250mm and a side 350mm along with my Asus royal knight cou cooler which is so tall it sits too damn close to the side fan (if you push on the outside fan the touch so I have a strict hands off policy when running).
I dunno if it has +/- pressure but it's open well enough with HDD cage and right side vents that it wouldn't matter one way or the other and probably stays balanced
Vacuum vs Blower General Discussion
