Vista - Are you a Sucker or a Blower.
Old 08-22-2009   #1 (permalink)
Vista Ultimate x64, SP2
I was just wondering how different users have there fans setup, blowing hot air out, or, sucking cooler air in.
What do you think is best, and of course, if anybody has any tips they want to share, all the better.
Old 08-22-2009   #2 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
I have mine arranged as follows.
  • In-flow2 x 80mm front mounted (one above the other), draws cool air over the HDDs and into the case. Additional inflow through vents in side of case.
  • Exhaust 1 x 120mm rear mounted fan and also the fan built in to the PSU. (2 effective exhaust fans).
Ideally, you should arrange for a balanced air flow. The amount of air being fed into your system by the in-flow fans should be less or equal to the amount being removed by the exhaust ones. Any imbalance is taken up by air flowing into your case through its vents. You can easily check this by holding your hand over the main exhaust fan to feel the air flow coming through it. This should feel smooth and not too hot (mine feels cool). If you have an imbalanced system, i.e. one with more air in than out, then you are in danger of overheating.
Old 08-23-2009   #3 (permalink)
Vista Ultimate x64
I have two 120 mm's in the front, sucking cool air in. Then another 120mm inside the case attached to my HDD rack, to support the 120mm in front and get more air to the GPU. Then one 120mm on my Heatsink, another one on the back panel and another on top. So that's 2 sucking in (the one on the HDD rack is more of a 'transporter') (3with the heatsink one) and 2 blowing out the back. My airflow runs from bottom front to top back in diagonal path troughout the case (can you visualize it?)
Cheers,
Amplid
Old 08-23-2009   #4 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
Quote  Quote: Originally Posted by Dwarf View Post
Not in my case (no pun intended )
Since my case is so 'open' it's primarily a 'blow' configuration.
  • 1x230mm, 1x120mm front intake
  • 4x120mm side intake
  • 1x120mm inside front (augments front 230mm)
  • 1x120mm bottom of case intake (basically keeps 2nd video card cooler)
  • 1x230mm top exhaust
  • 1x140mm rear exhaust (basically useless)
It works for me
Old 08-24-2009   #5 (permalink)
Vista Home Premium 64-bit
I suck and blow, 1x120 intake front, 1x120 intake hd area, 1x120 exhaust upper, 2x120 top exhaust,
Old 08-24-2009   #6 (permalink)
ultimate 64 SP1
i suck far more than i blow.....lol
3x 120mm intake
1x 80mm intake
2x 120mm exhaust
Old 08-24-2009   #7 (permalink)
Vista Ultimate 64-bit, SP2
My laptop is a very quiet sucker & blower.
Old 08-24-2009   #8 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by skunksmash View Post
3x 120mm intake
1x 80mm intake
2x 120mm exhaust
Sucker!!
Old 08-24-2009   #9 (permalink)
Vista Home Premium 64bit SP2
if you suck more air in than your blowing out or vice versa it creates a volume of trapped air that circulates around the case getting hotter and hotter (to a point obviously im not saying it gets to 100 degrees or out )
you need a good balance of "suck" and "blow" this can also be balanced out with vents or small holes in the case sides as are often present in new cases.
the differance between balanced and unbalanced cooling can be small but as your asking...........
Old 08-24-2009   #10 (permalink)
Vista Ultimate x64 sp2, Solaris x64
Quote  Quote: Originally Posted by JMH View Post
Mine is two fun blower.
Vacuum vs Blower General Discussion
