8400GS overclock
mansrm81
Is it a good idea to overclock this card and is there any good performance increases?
Also what is a good program to test the stability of the overclock.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
With 8 series cards, overclocking usually improves things. Use GPU-Z to monitor temperatures and RivaTuner to increase MHz.
The best approach is to increase the memory or core clock by 5 MHz, then run a game for a short period and look for visual artifacts. Do this while logging temperatures with GPU-Z. As the MHz increase becomes extreme run prolonged graphically intensive temperature and artifact tests.
Depending on situation a 30% overclock is indeed possible.
    Dell Dimension 9200
    Intel Core 2 Duo 2.66 GHz
    2.00 GB
    Nvidia 8600 GTS (Overclocked)
    Dell 2007 WFP 27 in LCD
    1680 x 1050
    One (72.8/455 GB)
    Standard Dell Keyboard (Dusty)
    Razer Salmosa
The 8400gs is not a gaming card, and should probably not be overclocked. It's a budget card that it more geared towards multimedia than gaming.
Personally, I wouldn't recommend overclocking anything lower than a x800gt series(8800GT, 9800GT, etc)
Even if you do overclock that card, it woun't be much and you won't see a notciable difference, especially with the rest of your system.
Using the apps Macavity suggested, you could give it a go. But as CH mentioned, you're unlikely to notice any real improvement.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
Just to make it three comments on the negative side ;)..............dont bother , the only real improvement you see overclocking gpu's is when you ramp up the memory alongside the core , if you try and oc the memory on that card it'll meet a very untimely end , or at the very least get very very hot and artifact all over the place , sorry :p
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
Well I'll back down then... and go up my 8600's memory clock another few megahertz :p.
    Dell Dimension 9200
    2.00 GB
    1680 x 1050
    One (72.8/455 GB)
    Razer Salmosa
I had this card earlier this year (ASUS) was a pretty okay card,I overclocked it on stock and went pretty far.I could play Crysis on Medium-High settings.Hope this helps.
    AMD 4800+ 2.5GHZ Dual Core
    Asus M2A-VM
    Kingston 2GB
    eVGA 9800GTX+
    Sound Blaster 5.0
    Random
    1600 X 900
    Seagate 500GB & Western Digital 250GB
    Cooler Master
    Haf 922
    Fans
    Microsoft
    Cable
i was just about to say this.......
GPU OC's are flaky at best, unless you can pull a pretty high (stable) OC its a pointless exercise...
GPU's run VERY hot by default, & a few mhz over stock will send a lesser cards temps through the roof (& im not saying your cards crap, its just not ''high end'' & has cooling relative to that.)
if you are able to pull a pretty decent OC, b/c its lacking ''SP's'' your only likely to gain 1-2fps increases...
IMHO.....buy a newer card, even a jump to an 8800GT will be ''night & day'' difference from the 8400GS (they're dirt cheap now) ;)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech EX110
    logitech cordless optical
    2mb
I am considering overclocking my 8400M GS card.
Right now its temperature is a rather pedestrian 53 decrees Celcius. I have heard that anything below 60 is absolutely fine and safe for the card.
At any rate, the latest NVIDIA-authored forceware for cards operating on 64-bit Vista or 64-bit Windows 7 operating systems is here.
32-bitters find NVIDIA forceware here.
Both are supposed to work fine with DirectX 9 and 10.
And of course:
Learn how to uninstall your old drivers and prepare your system for integrating forceware properly here.
I'm going to take it slow and post back on results. I don't play any games except for GTA San Andreas. :/
This will be my very first time overclocking anything. :)
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock
    stock Synaptics Pointing Device
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246
    I like chocolate milk!
Is that your idle or load temps?
It's the load temps you have to worry about.
Good luck :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
