Vista - What are your Lowest Cooling Temps?
Old 09-04-2009   #11 (permalink)
Vista Home Premium 64bit SP2
Re: What are your Lowest Cooling Temps?
Quote  Quote: Originally Posted by mattinahat View Post
Quote  Quote: Originally Posted by archie123 View Post
matinahat...........yuor cores will always read differantly
Differently even though those temps were taken at the exact same time in three different programs?
I'm not talking about the variance in core temps, I am talking about the variance between programs and the temps they report.
sorry yes i see what you mean ....... its complicated the way temps are measured they dont take i direct temp measurement from the sensor there is some math involved and as intel dont reveal the exact way this temp should be measured or the chips TJmax its always a best guess on the side of the program writer (ill try and find a link that describes this better than me)
i can tell you that Real Temp is widely regarded in the overclocking community as the one to use so i just go with that , the writer spends alot of time cofiguring his software using his own temp sensors and equipment
hope this makes it a little clearer than mud for you :P
Old 09-05-2009   #12 (permalink)
ultimate 64 SP1
as of 30 secs ago....
Old 09-05-2009   #13 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
Hey Mitch, you might want to update your specs
Old 09-05-2009   #14 (permalink)
Vista home premium 32bit
You must be careful with AMD processors. It is not an exact measurement but a calculated value - see here ( Core Temp - How it works ). On an AMD 4800+ I have seen temperatures as low as 8C (in Florida).
Old 09-05-2009   #15 (permalink)
ultimate 64 SP1
Quote  Quote: Originally Posted by smarteyeball View Post
lol..... oh yeah
Are these temps right? Overclocking & Cooling
Temps Before and After Overclocking & Cooling
Charting the highest and lowest values PowerShell
cpu and core temps Overclocking & Cooling
LCD Display Resolution Resets to Lowest on Startup and After Sleep Vista performance & maintenance
