Vista - What are your Lowest Cooling Temps?
Old 08-31-2009   #1 (permalink)
Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86
Here are mine with Three 80mm Case fans and my cpu cooler.
what are yours?
Old 09-01-2009   #2 (permalink)
Vista Home Premium 64bit SP2
Re: What are your Lowest Cooling Temps?
i saw 24 degrees once ........... years ago with an overclocked athlon 4800 dual core skt 939 on a thermaltake big typhoon with a 120mm fan , that was just my idle temps mind
now im looking at 30-36 idle (depending on how high the wife has the heating) and 50 or under during load , im happy with that for now , my cpu is it its max stable OC anyway i cant do any better
even if i boot up and run HW monitor straight away i wont see as low as 24
Old 09-01-2009   #3 (permalink)
Vista Ultimate 64-bit
you guys obviously havent seen my rig in the forum...
Old 09-01-2009   #4 (permalink)
Vista Ultimate x64 SP1
From top to bottom, HW Monitor, Core Temp and Everest.
All three were screenshot at the same time which makes you wonder why they are giving different values.
Old 09-01-2009   #5 (permalink)
Quote  Quote: Originally Posted by alexdagr8est View Post
yes i have ive even commented on it
Old 09-01-2009   #6 (permalink)
oh and i forgot to mention i have EIST and Speedstep turned off , that doesnt help my offload temps either
matinahat...........yuor cores will always read differantly
Old 09-02-2009   #7 (permalink)
Thanks Archie I know mate
I gave that rig to my brother after I had my fun with it, but I never really took many pics of it or anything, i'll have to see if I can get some screenshots of the CPU speed running stable, give me some weeks guys, my brothers in another state.
Oh and those temps..... lol I could have pushed it more, but you melt the bottom of the motherboard going that extreme in the overclock.
So my temps on the top side were between probably negative 120-196 degrees Celcius and on the bottom, 80 degrees, if only i hade made a heatpipe to go around and under the board. (that's why I didnt, there is no place to put thermal paste-duh - destroy my rig why dont I).
Old 09-03-2009   #8 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
There's not really much difference between Air cooling and a liquid nitrogen setup... give or take a couple of hundred degrees
Anyway, this was during winter and is the coolest I ever saw my rig:
Now it's warming up a bit (22.4C)
Ever since I put some ghetto filters on my intake fans, the ambient temp inside has risen a few extra degrees. I'm not looking forward to summer
Old 09-03-2009   #9 (permalink)
ROFL, just a few hundred degrees... yeah sounds about right.
Old 09-04-2009   #10 (permalink)
Quote  Quote: Originally Posted by archie123 View Post
Differently even though those temps were taken at the exact same time in three different programs?
I'm not talking about the variance in core temps, I am talking about the variance between programs and the temps they report.
Are these temps right? Overclocking & Cooling
Temps Before and After Overclocking & Cooling
Charting the highest and lowest values PowerShell
cpu and core temps Overclocking & Cooling
LCD Display Resolution Resets to Lowest on Startup and After Sleep Vista performance & maintenance
