| Vista ultimate x64 | is there a program that says my cpu temp is there a program that says my cpu temp??? |
| Vista home premium 32bit | Re: is there a program that says my cpu temp There a quite a few. I use Core Temp ( Core Temp ). |
| Vista Ultimate x64, SP2 | Re: is there a program that says my cpu temp Hello Mike8629, Use SpeedFan, it's a good temp tool. Download SpeedFan - Access temperature sensor in your computer Hope this helps, good luck. |
| Vista Ultimate x64, SP2 | Re: is there a program that says my cpu temp There a quite a few. I use Core Temp ( Core Temp ). LOL. i thought i was quick. |
| Vista Home Premium 64bit SP2 | Re: is there a program that says my cpu temp this is good one too for voltages cpu temps and gpu temps , its min/max/current temp/voltage listing can also be very handy edit..forgot the bloody link lmao http://www.cpuid.com/hwmonitor.php |
| CPU Temp | General Discussion | |||
| Windows Vista strange settings on temp folder AppData\Local\Temp\1 | Vista security | |||
| PC Temp | Overclocking & Cooling | |||
| Uninstalled Program, but Program Name Remains in Program & Featur | Vista General | |||
| temp | Vista mail | |||
