Vista - ALMAN 9500A 92mm 2 Ball CPU Cooler with evga 790i ultra sli
Old 09-20-2009   #1 (permalink)
vista home premium 32-bit
i have a problem, i bought the zalman 9500A for my 790i ultra sli motherboard but the northbridge heatsink gets in the way, the "clip lever A" won't snap in the "lug" if anyone have managed to install it i would appreciate it if you help me, because I'm about to return it. -thanks
Old 09-20-2009   #2 (permalink)
Windows 7 x64
Re: ALMAN 9500A 92mm 2 Ball CPU Cooler with evga 790i ultra sli
Have you tried rotating it about 90 degrees to see if it fits that way? You should be able to rotate the bracket, so it fits on at a different angle. If you do, then it's best to have it blowing out the top of the case.
Old 09-21-2009   #3 (permalink)
Vista Home Premium 64bit SP2
its all over google , it doesnt fit your board
Quote:
THE HEATSINK AROUND THE MOTHERBOARD GETS IN THE WAY OF THE CLIP
evga 790i board + zalman 9500a doesn't work (4/2/2008 8:40:23 PM)
Quote:
Im starting to get very ****, the zalman cnps-9500a doesn't fit no matter what way you try it
the mounting bracket that gets screwed down into motherboard cannot be positioned any other way, you can only mount that part the correct way with the little circle notch aligned so the locking arm can open
the vreg heatsink closest to the memory slots blocks the clip from going all the way down and clipping
WTF evga!!! or better yet foxconn, since there the oem makers of this board
Old 09-21-2009   #4 (permalink)
Windows 7 x64
Seems you can't do the suggestion I posted as the 9500 uses different fittings to the 9700, which is probably why the 9700 seems to work.
Old 09-21-2009   #5 (permalink)
thanks guys... i guess i will be returning it.
and does anyone know of other zalman coolers that will fit with the ultra 790i or any other good quality cooler-thanks
Old 09-30-2009   #6 (permalink)
Vista Home Premium 32bit and Ubuntu 9.10 32bit
um............ look into the coolermaster v10.... or something along that line... i think its nautica that makes cpu coolers they have some good ones
Old 10-06-2009   #7 (permalink)
ultimate 64 SP1
Quote  Quote: Originally Posted by thepizzaman View Post
lol.....if he's got trouble fitting the Zalman 9500, i dont think this monster will be much better...
its not a very good cooler IMO, i'd look at ''scythe'' coolers, they've got some great heat sinks...
CPU Cooler Overclocking & Cooling
cpu cooler Overclocking & Cooling
Move Vista64/780i to 790i? Drivers
Ultra-ultra slow! Vista performance & maintenance
thermal right ultra 120 extreme cooler or zalman cnps9700 Overclocking & Cooling
