| ultimate x64 | Hey does this look normal? |
| ultimate 64 SP1 | Re: Hey does this look normal? temps look good mate....... |
| Windows Vista Enterprise x64 SP2 | Re: Hey does this look normal? Ditto... |
| ultimate x64 | Re: Hey does this look normal? Thanks guys, I was little concern though with the first process on the list being little higher then other 3. As you can see i'm a nob at this sorta thing. |
| Vista 32 win 7 7600 32 bit | Re: Hey does this look normal? ken |
| | #6 (permalink) |
| Vista Ultimate x64, SP2 | Re: Hey does this look normal? Hello ndd63, Your temps look fine, but if you really want to give them a test, put your CPU under load for a while and then take a reading, it's the temp under load that counts. Give it a go and post your results, good luck. |
| | #7 (permalink) |
| ultimate x64 | Re: Hey does this look normal? I will do that stoney, any suggestion on what will give it a good stress test? i'm not really a gamer but on occasionally I do like to play crysis. Its great to have great people here helping each other. |
| | #8 (permalink) |
| Vista Ultimate x64, SP2 | Re: Hey does this look normal? Try this for a Burn in Test, it's a free app that will stress test your CPU and diagnose MB problems. Please be aware that stress testing can damage your CPU, so just go steady with it. free stress test cpu heat download If you are only an occasional gamer, and you don't over clock, you don't really need to worry too much about heat, although it never hurts to keep an eye on these things. Good luck and post your results. |
| | #9 (permalink) |
| ultimate x64 | Re: Hey does this look normal? Will do stoney, and thanks very much for good info. |
| Just how much resource use is normal for WLM? | Live Mail | |||
Is this normal? | General Discussion | |||
| Normal temp of a GPU? | Graphic cards | |||
| The Importance of being normal | Vista General | |||
| Is this normal? | Vista installation & setup | |||
