| | Vista - Is that overclocking?(the famous 1:1) |
| 10-10-2009 | #1 |
| | Is that overclocking?(the famous 1:1) My cpu is Q6600. I have read so many times about how good is the FSB : DRM 1:1 and that you gain extra speed and,and.... And i decide to give it a try. My cpu is 9x266 and my ram 800mhz So i changed the cpu to 6x400 and i set my ram to [2.00D] I also set manualy the ram timings in the correct (Factory Stock) 5-5-5-15 I DIDEN'T change anything else,no voltage,no vcore,NOTHING. Result: at last i get the famous 1:1 in cpuz (before was 2:3)and 5,9 in Windows Experience Index.(before was 5,6) so far so good. But i dont want to overclock,i dont want to damage my hardware. And i will like to know,are all the above normal changes or is everclocking and maybe it will damage my hardware? Last edited by panais; 10-10-2009 at 09:58 AM.. |
| My System Specs |
| 10-10-2009 | #2 |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 Doncaster, UK | Re: Is that overclocking?(the famous 1:1) Hi panais, You have not overclocked. Your CPU runs at a frequency which is governed by the product of the FSB and the multiplier. Calculations: 9 * 266 = 2394 MHz and 6 * 400 = 2400 MHz. As you can see, your CPU is still running at the same clock frequency ~2.4 GHz. |
| My System Specs |
| 10-10-2009 | #3 |
| | Re: Is that overclocking?(the famous 1:1) Hi panais, You have not overclocked. Your CPU runs at a frequency which is governed by the product of the FSB and the multiplier. Calculations: 9 * 266 = 2394 MHz and 6 * 400 = 2400 MHz. As you can see, your CPU is still running at the same clock frequency ~2.4 GHz. Last edited by panais; 10-10-2009 at 10:23 AM.. |
| My System Specs |
| 10-11-2009 | #4 |
| | Re: Is that overclocking?(the famous 1:1) Setting the System Memory Multiplier to 2.0 will just keep your RAM at the rated speed of 800MHz as with DDR2, you half the rated speed, so 800 = 400MHz, then you have your multiplier to 2.0 so you're still just keeping the same 800MHz speed, so yea in essence is it correct having it at this setting. If you set it higher, you'd increase the RAM speed, but then you'd also remove the 1:1 ratio. |
| My System Specs |
| 10-11-2009 | #5 |
| | Re: Is that overclocking?(the famous 1:1) Setting the System Memory Multiplier to 2.0 will just keep your RAM at the rated speed of 800MHz as with DDR2, you half the rated speed, so 800 = 400MHz, then you have your multiplier to 2.0 so you're still just keeping the same 800MHz speed, so yea in essence is it correct having it at this setting. If you set it higher, you'd increase the RAM speed, but then you'd also remove the 1:1 ratio. So i changed the cpu to 6x400 and i set my ram to [2.00D] I also set manualy the ram timings in the correct (Factory Stock) 5-5-5-15 (!!I DIDEN'T change anything else,no voltage,no vcore,NOTHING.!! is that ok?my pc works fine) |
| My System Specs |
| 10-11-2009 | #6 |
| | Re: Is that overclocking?(the famous 1:1) Yea that's right, you've got 1:1 ratio, but like what Dwarf has said, you've not really overclocked everything as your CPU is still the same speed. If you're happy with leaving them at the same speeds, but keeping 1:1 ratio, then that's fine to stay with. |
| My System Specs |
| 10-11-2009 | #7 |
| | Re: Is that overclocking?(the famous 1:1) What is the different between [2.00A] [2.00B] [2.00C] [2.00D]? |
| My System Specs |
| 10-11-2009 | #8 |
| | Re: Is that overclocking?(the famous 1:1) The letters correspond to what FSB speed you have. 2.00A = 266 2.00B = 333 2.00C = 200 2.00D = 400 So as you have an FSB of 400, you have 2.00D. |
| My System Specs |
| 10-11-2009 | #9 |
| | Re: Is that overclocking?(the famous 1:1) |
| My System Specs |
| 10-11-2009 | #10 |
| | Re: Is that overclocking?(the famous 1:1) You will most likely need to increase the voltage. Increase the voltage by 1 increment then try booting again. If it blue screens/crashes, the increase the voltage a bit more. It shouldn't need that much more voltage, though. I use the timings of 5-4-4-12 2T with my overclocked RAM and just needed to increase the voltage by 1 increment and it works fine. |
| My System Specs |
| Similar Threads for: Is that overclocking?(the famous 1:1) | ||||
| The Famous "Access Denied" in Vista. | Network & Sharing | |||
| Overclocking Ram | Overclocking & Cooling | |||
| The famous Unable to choose recipients problem | Vista mail | |||
| Famous tech myths that just won't die | Vista News | |||
| Overclocking | Vista performance & maintenance | |||
