Vista - Really bad problems with graphics card and ram!?
Old 10-24-2009   #11 (permalink)
Vista Ultimate x64
Re: Really bad problems with graphics card and ram!?
Thanks i have sent it back i did underclock it! but oviously it fried my card a little bit. When u say you had to underclocked the ramm to stop is artifacting, Do u mean the ram on the graphics card or the physical ram sticks u insert! Please answer here
BSODS! Help
Old 10-24-2009   #12 (permalink)
Vista Home Premium 64bit SP2
no mate im referring only to your GPU memory , your physical ram wont be causing that issue
Old 10-24-2009   #13 (permalink)
Vista Ultimate x64
Attached is an anaylsis made by debbuging tools of the dump I had (i say had cos i dont have it anymore, ccleaner must of got rid of it) ah well this should be okay!
Old 10-24-2009   #14 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by archie123 View Post
Kk cheers now above is an attached copy of the anyalsis of the dump!
Edit: I also have lots of problems with right clicking as alot of the time it says windows explorer has stopped working. then it restarts explorer.exe and the taskbar comes back etc. but then its just a loop if i right click soon after!
Old 10-24-2009   #15 (permalink)
Vista Ultimate x64
I have lots of errors in memtest86+ on test 5, 6 and 8
5= 380 errors
6= 37
8=217
Old 10-24-2009   #16 (permalink)
Quote  Quote: Originally Posted by jonny321321 View Post
5= 380 errors
6= 37
8=217
any overclocking of the ram? how many sticks of ram and what make/manufacturer/type and how many sticks do you have to make up the 4gb (eg 2x 2gb 4 x 1gb)
and is that the offline (bootable) version of memtest?
Old 10-24-2009   #17 (permalink)
Vista Ultimate x64
I got 2x2gb of ocz ram. ddr2-800
Old 10-24-2009   #18 (permalink)
i need to know the exact type of ram mate/model number for example mine is OCZ PC2 8500C5.....there is a reason for this , some high end ram runs at 2.1 to 2.3 Volts especially the OCZ stuff now your motherboard bios by default will be sending out 1.8 Volts the the ram , it may be a simple isuue of upping the voltage to your DDR to solve the problem , if you can tell me exactly what ram you have i can see what voltage it runs at
Old 10-25-2009   #19 (permalink)
Vista Ultimate x64
This is my ram
OCZ OCZ28002G 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Thats applies to both sticks!
Thanks
Thanks so much iv been having problems with my new graphics card i instaled as well!
Old 10-25-2009   #20 (permalink)
Vista Ultimate x64
Attached is ram information from cpu-z!
"Startup Repair" loop and graphics card problems General Discussion
Updating Graphics Card Problems (I'd Like to Uninstall the Update) Vista hardware & devices
Geforce 7900 GS graphics card problems. Vista General
graphics card problems Vista hardware & devices
graphics card problems with ati radeon x300 Vista hardware & devices
