Vista - Really bad problems with graphics card and ram!?
Old 10-25-2009   #21 (permalink)
Vista Ultimate x64
Re: Really bad problems with graphics card and ram!?
Attached is some other useful info regarding my mainboard!
Old 10-25-2009   #22 (permalink)
Vista Ultimate x64
SiSoftware Sandra
Computer
Model : System manufacturer System Product Name
Workgroup : .................
Host Name : ..................
User : Administrator
Processor
Model : Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
Speed : 3GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Asus P5KPL-AM
BIOS : American Megatrends Inc. 0518 07/08/2009
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DIMM DDR2
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 240MHz (960MHz)
Memory Bus Speed : 2x 480MHz (960MHz)
Memory Module(s)
Memory Module : OCZ OCZ2G8002G 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Video Adapter : NVIDIA GeForce 7800 GT (20 PS3.0, 7 VS3.0 450MHz, 256MB DDR3 2x1GHz, PCIe 1.00 x16)
Storage Devices
ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C
SONY DVD RW AW-G170A (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (D
JC0543R AVU829Y (SCSI, SCSI-2, DVD+-R-DL, CD-R, 512kB Cache) : 4GB (E
Logical Storage Devices
Hard Disk (C : 466GB (NTFS) @ ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Optical Drive (D : N/A @ SONY DVD RW AW-G170A (ATA66, DVD+-RW, CD-RW, 2MB Cache)
3.5" 1.44MB (A : N/A
SEGAROME (E : 4GB (UDF) @ JC0543R AVU829Y (SCSI, SCSI-2, DVD+-R-DL, CD-R, 512kB Cache)
Peripherals
LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller
LPC Legacy Controller 1 : T0 B0-73h
Audio Device : ASUS 82801G (ICH7) High Definition Audio
Audio Codec : VIA VT1708B 8-channel High Definition Audio CODEC
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller
Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller
USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller
USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller
USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller
USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller
USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : KODAK ESP-3 AiO (600x600, USB, Colour)
Printer : HP PSC 750xi (1200x1200, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Scanners and Cameras
Scanner : Hewlett-Packard HP PSC 750xi (Scanner, USB)
Network Services
Network Adapter : Realtek PCIe FE Family Controller (Ethernet, 100Mbps)
Wireless Adapter 1 : D-Link AirPlus G DWL-G510 Wireless PCI Adapter(rev.C) (802.11g (ERP), WEP n-bit, 54Mbps)
Wireless Adapter 2 : Wireless-G USB Network Adapter with RangeBooster #2 (802.11g (ERP), WEP n-bit, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows Vista Ultimate 6.00.6001 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.7
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
EDIT: I dont know why all the :P came up?
Old 10-25-2009   #23 (permalink)
Vista Ultimate x64
Also when i did a test with sis sandra for memory bandwidth. It tells me all about the ram. It says Total Memory = 4gb, and then memory used by test = 2gb
does this mean that only 2 gb can be used and the other 2gb is either bad or not compaitable, or does it mean that 2gb only needed for the test or its the max supported for that test?
It also says under tips
System bandwidth appears fsb limited. Attempt to increase fsb
and
Cannot use large memory pages due to lack of privilages
Old 10-25-2009   #24 (permalink)
Vista Ultimate x64
Attached is a log of the intel identification utility!W222
File Type: txt Intel Processor Identification Utility Log.txt (1,023 Bytes, 7 views)
Old 10-25-2009   #25 (permalink)
Vista Home Premium 64bit SP2
ok more silly questions , searching OCZ site throws up three types it could be with the info from CPUz
OCZ Technology | Products | Memory | OCZ DDR2 PC2-6400 Gold GX XTC Dual Channel
OCZ Technology | Products | Memory | OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
OCZ Technology | Products | Memory | OCZ DDR2 PC2-6400 Vista Performance Gold Edition
which one do you have?
the first one will operate safely at 1.9V the second 2 at 2.1V (they are all 1.8v by default but dont worry about that)
see sometimes the reported voltage and actual voltage can be differant also some motherboards can fall short of "getting enough juice" to the ram to make it work effectively so we need to up the voltage to the ram to eliminate that as a possibility as to why its not working , now after we tested it this way if its still failing its RMA time (return to manufacturer)
in which case you will have to go here OCZ Forum - Powered by vBulletin and post your problem in the support section , they will then talk you through all the tests and if the deem your ram to be faulty they will give you an RMA number so you can return your ram for new stuff (OCZ has a lifetime warrenty and they are very good at the customer service end)
dont worry about me asking you too up the voltage to the ram i wont ask you to up it any further than OCZ's warrenty allows
Old 10-25-2009   #26 (permalink)
Vista Ultimate x64
I have the middle one dual kit!
Old 10-25-2009   #27 (permalink)
i have a problem......ive just found out your overclocking your cpu!! what cpu/ram ratio are you running? what speed is your ram currently running at now? it may be unstable due to the OC you bloody clown
anyhoo , you can safely up the voltage to your ram to 2.1 volts (OCZ will warrenty it up to that limit for overclocking purposes) it will be in the advanced settings in your bios under (beleive it or not) voltage
you normally up it ny steps of .1 of a volt you can up yours by a max of .3 , thats POINT 3 not 3 (i have to point this out as i was cought out by a moron once who thought i asked him to up the voltage to his ram by 5 volts!!)
I have to go now and watch the X factor with the wife , ill check in later good luck
Old 10-25-2009   #28 (permalink)
Vista Ultimate x64
Lol cheers ill keep u updated on this post and pm cheers for ur help ill up it to 2.1 then ill see if prime95 crashes it probally will, if it does ill put the cpu back to 2.50 and then make my way back up running prime95! Cya cheers u have been so helpful!
"Startup Repair" loop and graphics card problems General Discussion
Updating Graphics Card Problems (I'd Like to Uninstall the Update) Vista hardware & devices
Geforce 7900 GS graphics card problems. Vista General
graphics card problems Vista hardware & devices
graphics card problems with ati radeon x300 Vista hardware & devices
