Really bad problems with graphics card and ram!?
  1. #1
    Banned
    England
    Vista Ultimate x64
    Local Time: 12:51 PM
    uk uk city of london
    http://forums.nvidia.com/lofiversion/ind…
    this relates to my problem but when playing games (cod4) every 2 mins all the textures go weird like pink and black and all weird colours and it freezes when i press alt del and ctrl it fixes again so then i click cancel and continue playing. It happens all the time. My next problem is that cod4 just froze properly and nothing worked except cutting the power. When it restart bsod came up. this has happend twice so far once with cod4 and once with rome total war. the website above links greatly to my issues. when the pc came back on in safe mode i had a problem reports and sollution window come up and say:
    Description
    A problem with your video hardware caused Windows to stop working correctly.
    Problem signature
    Problem Event Name: LiveKernelEvent
    OS Version: 6.0.6001.2.1.0.256.1
    Locale ID: 1033
    Files that help describe the problem
    WD-20091017-1121.dmp
    sysdata.xml
    Version.txt
    View a temporary copy of these files
    Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
    Extra information about the problem
    BCCode: 117
    BCP1: FFFFFA80061114E0
    BCP2: FFFFFA60024E9220
    BCP3: 0000000000000000
    BCP4: 0000000000000000
    OS Version: 6_0_6001
    Service Pack: 1_0
    Product: 256_1
    i have 4 gigs of ram vista 64bit ultimate and nvidia 9800gt i have tried 5 different drivers ranging from old beta and new! Please help. it could be deffective ram or my video card! Thanks
    I also get nvddklmm.sys has stopped working regulary! (thats with games like crysis and far cry2)
  2. #2
    Banned
    England
    Vista Ultimate x64
      Thread Starter
    Re: Really bad problems with graphics card and ram!?
    i have loads of dump files!
  3. #3
    H2SO4's Avatar
    A bit of a numpty
    Australia
    Win7x64
    Local Time: 06:51 AM
    australia
    Quote Originally Posted by jonny321321 View Post
    If they're all stop 0x117s, there's nothing to see in those dumps.
    0x117 = VIDEO_TDR_TIMEOUT_DETECTED. The OS has noticed that the combination of driver+video hardware has been unresponsive for an unacceptably long period of time. Suggestions:
    1) Make sure you're on the latest video drivers.
    2) Don't overclock anything.
    3) Make sure the box is adequately cooled.
  4. #4
    Banned
    England
    Vista Ultimate x64
      Thread Starter
    My card is factory overclocked by xfx but i did fiddle (although that was a while ago long time before my problems with a different pc) ill change it back to default
    Im on the latest drivers
    All the temps are fine i think my gpu is: 60 celcius idle
  5. #5
    Banned
    England
    Vista Ultimate x64
      Thread Starter
    Also the resolution changes without me doing anything alot of the time. and i get alot of explorer has stopped work and then it restarts!
  6. #6
    H2SO4's Avatar
    A bit of a numpty
    Australia
    Win7x64
    australia
    My card is factory overclocked by xfx...
    A loosely translated version of that statement:
    "The card was made by a company which is sufficiently unscrupulous to charge more for configuring components to run outside of their design envelope."
    My advice would be to avoid similar products (and companies) in the future. Hardware which is "overclocked" is by definition more prone to failure.
  7. #7
    Banned
    England
    Vista Ultimate x64
      Thread Starter
    yeah i know but it was the same price and i thought what the hell. and it came with free assassins creed so i was happy its at the overclocked default now should i underclock it with rivatuner? Or is it not related to the overclocking and its just screwed or what please help!
  8. #8
    Old and cranky
    Southeastern CT, USA
    Vista Ultimate x64; Win 7 x64 and x32
    Local Time: 07:51 AM
    usa us connecticut
    Overclocked = decreased lifespan of the component
  9. #9
    Banned
    England
    Vista Ultimate x64
      Thread Starter
    my cpu is overclocked @3.01 GHz its e5200 (originally @ 2.50)
    my mothered board is p5kpl-am
  10. #10
    archie123's Avatar
    I Tunes hates Me
    UK
    Win 7 Home Premium 64bit
    uk uk yorkshire
    Quote Originally Posted by usasma View Post
    usually that can be the case but factory overclocked stuff especially from XFX use cherry picked core's and ram they come with a full manufactrers warrenty and with XFX its lifetime (however long they deem a lifetime to be
    Can you underclock your card? start with the memory first see what happens , (i think this is your culprit) then move onto the shader clock then lastly the core , try a benchmark each time you underclock something.
    i had a factory overclocked 6800 from XFX years ago i had to underclock the ram to stop it artifacting , it didnt do what it said on the box so i sent it back and they replaced it
    the overclock could have fried your card ram , if it has its their fault and they will replace it , but you will have to contact their tech support and go through all the tests they ask you , i have dealt with them they are very good and if they deem your card faulty they will replace it free but you will have to pay the shippin to send your old card back
    and be ready the first thing they will blame is your PSU :P
Page 1 of 3 123 LastLast
Really bad problems with graphics card and ram!? problems?
graphics card problems daquinnsta Graphic cards 7 22 Jan 2010
Updating Graphics Card Problems (I'd Like to Uninstall the Update) Steven Vista hardware & devices 1 13 Jan 2008
Geforce 7900 GS graphics card problems. chama98 Vista General 1 02 Apr 2007
graphics card problems Bill Vista hardware & devices 5 01 Apr 2007
graphics card problems with ati radeon x300 Rorypie Vista hardware & devices 4 21 Jun 2006
