| Vista Ultimate 32bit, 7 Ultimate x64 | Cooling and one more thing... Hey guys, I have two questions here, What would be a good liquid cooling system for my PC which is under 200$ (CPU and GPU). I am having hard time finding one cheap.. ![]() 2nd. Does higher resolutions affect our eyes more or less than lower resolution? I currently run on 1680X1050. |
| Vista Ultimate x64 | Re: Cooling and one more thing... Hey guys, I have two questions here, What would be a good liquid cooling system for my PC which is under 200$ (CPU and GPU). I am having hard time finding one cheap.. ![]() 2nd. Does higher resolutions affect our eyes more or less than lower resolution? I currently run on 1680X1050. Don't take my workd for this though. haha |
| Vista Home Premium x86 SP2 | Re: Cooling and one more thing... Answer to the second: Its not only your resolution but also how big your monitor is. If you use a high res on a small monitor Eg: 1280x960 on a 15in monitor, the text will be too small and you'll strain your eyes. What is your monitor dimension? My personal setting would be the highest resoulution in which i can read the usual text without straining from about 4 feet. |
| Vista Ultimate 32bit, 7 Ultimate x64 | Re: Cooling and one more thing... Well my monitor size is 22 inches, |
| Vista Ultimate 32bit, 7 Ultimate x64 | Re: Cooling and one more thing... Ops, sorry forgot a thing, I even use my laptop with 14.1'' screen running on 1280X800 so are these fine? |
| | #6 (permalink) |
| Vista Home Premium x86 SP2 | Re: Cooling and one more thing... Is your monitor L:W ratio? The resolution you mentioned is 16:10. You could comfortably use 1920x1200. |
| | #7 (permalink) |
| Vista Ultimate 32bit, 7 Ultimate x64 | Re: Cooling and one more thing... Well, My monitor does not support 1920x1200 resolution so the highest it supports is 1680x1050 and i have applied that. |
| | #8 (permalink) |
| Vista Home Premium x86 SP2 | Re: Cooling and one more thing... Thats good enough i guess. You need not reduce it unless you have problems reading stuff. |
| Biggest and best cooling | Overclocking & Cooling | |||
| Fan cooling | Overclocking & Cooling | |||
| Cooling a 9800GX2 | Graphic cards | |||
Air Cooling praise | Overclocking & Cooling | |||
| What cooling PAD Should i choose? | General Discussion | |||
