| | #11 (permalink) |
| Vista Ultimate x64, SP2 | Re: E8500 temps and question The important thing is to have air flow, if you do that the air will just swirl around going nowhere. You need to get air flowing through the case. |
| | #12 (permalink) |
| Windows 7 x64 and Windows XP professional on Desktop | Re: E8500 temps and question sorry for the late reply it has an exhaust fan in the back, im going to take apart my old heat sink fan and put it on the side of the motherboard so it has a side exhaust fan Currently i am running 3 hard drives, 4 fans, and a 8800GT on a 600 PSU u think it would hurt adding a 5th fan? the fans in back is Power supply and another one below it, that means i have 2 exhaust fans in back im thinking i should make a 3rd but on the side i have a power plug in for it Last edited by naturalphenomen; 10-28-2009 at 08:53 PM.. Reason: edit |
| | #13 (permalink) |
| Vista Ultimate x64, SP2 | Re: E8500 temps and question A 600W PSU will handle that OK. As long as you have good air flow through the case you wont have any problems. Hope it all goes well for you, good luck. |
| | #14 (permalink) |
| Windows 7 Ultimate x64/Vista Ultimate x64/XP Pro x86/Fedora 12 X64 | Re: E8500 temps and question you'd have to weld it on or something |
| Overclocking Temps? | Overclocking & Cooling | |||
| Are these temps right? | Overclocking & Cooling | |||
| Temps Before and After | Overclocking & Cooling | |||
| cpu and core temps | Overclocking & Cooling | |||
| CPU cooler/temps? | Vista hardware & devices | |||
