Vista - useing easytune
Old 3 Weeks Ago   #1 (permalink)
Vista home basic 32bit
useing easytune
i am pertty impressed with the easytune programe on my computer. my room is very warm at the moment and i switched the smart fan to diabled instead of being on auto, and the fan speed went up past 3000RPM and the temp of my computer dropped from 50 dergess to 43 and lower.
its a good little way of cooling the system down. now my fan speed is sitting on 2743RPM and by doing this, would i be useing more power?
i would like to know what other people have got with there system temps if that is ok?
Old 3 Weeks Ago   #2 (permalink)
Vista Ultimate x64, SP2
Re: useing easytune
These are my temps after about one hour.
You can see the fan speeds on the CPU and GPU.
Your fan speed is fine, it will use a bit more power, but to be honest you wont see or notice any difference.
Hope this helps, good luck.
Old 3 Weeks Ago   #3 (permalink)
Vista Home Premium 64bit SP2
Re: useing easytune
are you talking about your cpu temp?? even 43 degrees is high off load! id get myself some third party cooling if i were you
EasyTune is OK if all you want to do is turn off fan control , DONT overclock with it though!! I have nothing against overclocking i do it to every cpu i own but never be tempted to use third party software
Old 3 Weeks Ago   #4 (permalink)
Re: useing easytune
well i have tried to overclock it once on one level and that was cruise, 2 min later the windows locked up and had to intitate the fail safe defults from the bios, i will never try over clocking unless i upgrade my system OR some who is skilled at OCing.
useing windows mail. Vista mail
re-useing product key Vista installation & setup
useing OEM kety to go from 32-bit to 64-bit Vista Vista installation & setup
too many svchost useing too much RAM Vista General
useing optical through soundcard Vista General
