Vista - overclocking noob questions
Old 4 Weeks Ago   #1 (permalink)
Vista Ultimate 64-bit
currently, im running my proc at 3.6Hz with 1.456V. are there any negative side affects of "overvolting" the CPU like that? short and long term. plz post! =)
Old 4 Weeks Ago   #2 (permalink)
Vista 32 win 7 7600 32 bit
Re: overclocking noob questions
Quote  Quote: Originally Posted by chaosrealm93 View Post
You bet. short term reliability, BSOD's, etc. Long term for every 1% increase un performance you loose 1% of the componenets life span. They are designed to run at a certain voltage not more. As one of the ppl who debugs crash files here about half are related to overclocking, undervolting, etc
Ken J
Old 4 Weeks Ago   #3 (permalink)
thx man. one question, whats undervolting?
Old 4 Weeks Ago   #4 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
The opposite of overvolting
"Undervolting" is when you supply less voltage than the manufacturers specs for any chip to run at stock speeds.
The two biggest chip killers are excess voltage and heat (in that order)
Every CPU has a 'maximum safe voltage value' before degradation occurs. Exceding the max 'safe' voltage is a quick way to kill your chip. However if you keep within those values, you can be 'relatively safe' when o/cing.
It depends on how long you plan to keep your current hardware. Most Overclockers tend to replace there h/ware more often than others.
Overclocking is part science, part art and part luck
Old 4 Weeks Ago   #5 (permalink)
Vista Home Premium 64bit SP2
are you telling us that you overclocked and overvolted your cpu with absolutely no knowlage of overclocking? are you having a laugh????
If you knew anything about overclocking you wouldnt be asking that question , stop it now
how did you do it? third party app? your bios?
Higher voltages = higher temps , too much voltage = fried CPU
what did you use to test the stability of your overclock? what temperatures did your cores get up too?
Old 4 Weeks Ago   #6 (permalink)
yea, i OC'ed without much knowledge. i just knew that the higher the multiplier goes, the higher the voltage needs to be.
as for programs, i used CPU-Z, AMD Overdrive (to monitor my temps), and Prime95 (i heard its used to test stability)
as far as stability goes, i had to go back to 3.4GHz on 1.4V.
3.6GHz was apparently too much for the CPU and it crashed in the first few minutes of Prime95 =(
Old 4 Weeks Ago   #7 (permalink)
Vista Home Premium 32bit and Ubuntu 9.10 32bit
dude i'm jealous.... i want one of those cpu's... haha
Old 4 Weeks Ago   #8 (permalink)
nah.... get intel. overclocked AMDs are the equivalent to stock intels. thats how good they are.
Old 4 Weeks Ago   #9 (permalink)
who told you that? look at the overclock in my sig , thats at stock voltage
how do you know it was too much for the cpu? it could have been your ram , your fsb , your northbridge..............do some more research i demand it!!
really though mate your gonna fry that cpu if your not carefull
at least you got prime 95 , remember 8 hours blended tests maximum stress , then you'll know its stable
you didnt mention yor load temps , and what cooling are you using? your not still on the stock HS and fan are you
Old 4 Weeks Ago   #10 (permalink)
Quote  Quote: Originally Posted by archie123 View Post
Well... 8hrs is a good indication - 24hrs is better - even then it's not a 100% guarantee
(I have turned the air blue several times after P95 crashes/workers stopping at 9hrs+ )
Seriously though, do as Archie says and research this more.
OverClocking NoOb.... Some Help from the Vista Gods? Overclocking & Cooling
overclocking my pc help....NOOb Overclocking & Cooling
Need help (noob) General Discussion
Hello, noOb here Vista General
Some general (noob) questions on Vista 64 Vista General
