Fan cooling control question
  1. #1
    naturalphenomen's Avatar
    Senior Member
    Windows 7 x64 and Windows 7 x64 ultimate / professional on Desktop
    Local Time: 03:38 PM
    Does anyone know of a program that controls fan speeds? i want to turn up my fans higher but i dont know where to find a program that works well can some people give me links please?
  2. #2
    lil domii's Avatar
    Seven Guru + GFX
    i live at home...
    Windows 7 Ultimate 64 bit.
    Local Time: 09:38 PM
    england uk england
    Re: Fan cooling control question
    Quote Originally Posted by naturalphenomen View Post
    Fan speed control program - Club MyCE
    look at AZImmortal's post; u can't use software; the only software that is related is ones that monitor fan speeds. u can always buy a cheap hardware controller that yyou can change the speeds with from dials.
    Dom
  3. #3
    Senior Member
      Thread Starter
    well is there a program to monitor then? speedfan isnt working too well
  4. #4
    lil domii's Avatar
    Seven Guru + GFX
    i live at home...
    england uk england
    what is wrong with it?
  5. #5
    lil domii's Avatar
    Seven Guru + GFX
    i live at home...
    england uk england
    and anyway, here is another good one
    http://www.cpuid.com/download/hwmoni..._115_setup.exe
  6. #6
    smarteyeball's Avatar
    Eye know, eye know
    Australia
    7 Ultimate x64 : Vista x86 VM :W8 RP x64
    Local Time: 06:38 AM
    australia au queensland
    It depends on what fans, and how they are connected.
    ie CPU fans, case fans etc
    Are they Molex connections, Connected to the mobo, Do they have PWM etc.
  7. #7
    skunksmash's Avatar
    im coming for cake
    norfolk
    ultimate 64 SP1
    Local Time: 08:38 PM
    england uk essex
    depending on your BIOS settings the fans attached to motherboard headers will run 100% by default, the only one you can throttle through windows is the CPU HSF fan (providing its ''PWM'' enabled), via ''speedfan''
    ''speedfan'' will only alter fans that are ''PWM'' ready, these fans have a ''4pin'' connection to the board.
    so...... what fans are you talking about & how are they connected to your system.
  8. #8
    Blackhawk7188's Avatar
    Senior Member
    Reading PA
    Vista Home Premium x64 SP2/Ubuntu 10.04 LTS/XP Home Virtual PC 2007
    Local Time: 04:38 PM
    usa us pennsylvania
    Why not just leave them all at 100%? Keeping is cooler is always a good thing.
  9. #9
    stoneys-nutz's Avatar
    Gamerholic
    Wale's
    Vista Ultimate x64, SP2. XP Pro x64 SP3.
    uk uk scotland
    Quote Originally Posted by Blackhawk7188 View Post
    Thats OK if you are gaming all the time, (like me), but it kinda gets noisy when just browsing the web.
    naturalphenomen, can you tell us which fans you are talking about, the case fans or CPU/memory/GPU type fans.
  10. #10
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    Local Time: 02:38 PM
    usa us minnesota
    Unless you have a proprietary motherboard (HP,DELL,GATEWAY,etc.), Speedfan should work with any computer. works fine with my 790i
Fan cooling control question problems?
Water Cooling Question lil domii Overclocking & Cooling 26 24 Nov 2009
Cooling Program Question Prak06 Overclocking & Cooling 8 10 May 2009
Control panel question merlin2049er Vista General 2 21 Mar 2008
control panel question dla Vista performance & maintenance 0 20 Jul 2007
CONTROL PANEL QUESTION RENEE Vista General 8 19 Jun 2007
