Trying to OC to 3.20 GHZ. Going any higher than 2.99GHZ in BIOS Causing BSOD's.
  1. #1
    Banned
    FLORIDA
    Windows Seven Home Premium x64
    Local Time: 04:02 PM
    usa us florida
    I can't overclock my AMD Athlon 5000+ past 3.2GHZ. It'd be nice if I'd be able to do it, I have adequate cooling and just want to see how far I can push this ( as I have technically "Upgraded" to a Quad-Core processor, I just popped this thing back in to see how far I can push it.. )
    Some help please
  2. #2
    Jonathan_King's Avatar
    Senior Member
    Rednecksville
    Windows 7 x64
    usa us new york
    Re: Trying to OC to 3.20 GHZ. Going any higher than 2.99GHZ in BIOS Causing BSOD's.
    Have you tried increasing the voltage any? Be very careful, you can easily fry your CPU if you set it too high.
  3. #3
    Banned
    FLORIDA
    usa us florida
      Thread Starter
    I'll need to give that a try then. I'll post back the results. Problem here is, if I get the BSOD, the system automatically resets the clocks. What a PITA. :/
  4. #4
    skunksmash's Avatar
    im coming for cake
    norfolk
    ultimate 64 SP1
    Local Time: 08:02 PM
    england uk essex
    mate.....thats a pretty good OC for the Athlon, i dont think you can hope for much more on that chip.
  5. #5
    mpcrsc562's Avatar
    Westside Connected
    Long Beach
    Windows Vista Home Premium 64-bit
    Local Time: 01:02 PM
    usa us california
    Quote Originally Posted by skunksmash View Post
    i think i'll have to second that... i have a black edition 64x2 5400+ stock 2.8ghz. the best i could get it to was 3.3ghz--didn't want to try to get it any higher (and boy was it hot!)
  6. #6
    Banned
    FLORIDA
    usa us florida
      Thread Starter
    I've finally had the time to screw with it.. I got it to 3.06GHZ.. The temps the motherboard is giving me scares me, but touching the heatsink tells me that its not hot at all..
    I ran PRIME95 for 2 hours with no issues. I'm thinking of trying to crank it up even more.
    Seriously, took me all day to get it stable. Probably won't get around to a higher OC until next weekend when I am off of work..
  7. #7
    Banned
    FLORIDA
    usa us florida
      Thread Starter
    Anyone got any tips for increasing the speed any higher than 3.06? I've got adequate coolng and nothing to lose
    Seems to be now I push it higher I get BSOD/Hard lockups in Windows.. But this is expected.. 3.06 runs perfectly stable.. If I could get some more out of it, that'd be nice
  8. #8
    Senior Member
    Rednecksville
    Windows 7 x64
    usa us new york
    You could buy a better processor.
    If you have increased the voltage as much as you reasonably can, that is the best you can do.
  9. #9
    Banned
    FLORIDA
    usa us florida
      Thread Starter
    I've got a better processor
    Just want to find out how far I can push this one before I permanetly upgrade.
    This has been a damned good processor I've had it for a few years and never been able to OC it.
Trying to OC to 3.20 GHZ. Going any higher than 2.99GHZ in BIOS Causing BSOD's. problems?
Solved tcpip.sys causing BSOD illogik Network & Sharing 12 17 Oct 2009
NVIDIA drivers causing BSOD's Beast521 Drivers 39 12 May 2009
Multiple Driver Issues, causing BSOD's diablofan14 Vista hardware & devices 6 31 Mar 2009
Camera Driver Causing BSOD Rick95051 Vista hardware & devices 0 25 Feb 2009
Memory issues causing BSOD? Tiffer Vista hardware & devices 0 13 Feb 2008
