blue screen of death randomly
  1. #1
    Junior Member
    vista home 32bit
    Local Time: 11:45 AM
    every once in a while when internet explorer is open the syetem will bog down and a blue screen will come up saying the system is shutting down to protect itself
  2. #2
    Ashvin Busviah's Avatar
    Senior Member
    New Zealand
    windows 7/ windows vista/ windows xp pro/ windows server 2003
    Local Time: 05:45 AM
    newzealand
    Re: blue screen of death randomly
    it have many reasons why this may be happening.. try to check on event log what errors you have..
  3. #3
    stoneys-nutz's Avatar
    Gamerholic
    Wale's
    Vista Ultimate x64, SP2. XP Pro x64 SP3.
    Local Time: 06:45 PM
    uk uk scotland
    Hello kaossdruid,
    On IE, go to Tools > Manage add-ons > in the drop down box on the left, choose "All add-ons", then disable them and try IE, if all goes well, enable them one at a time to see which one is causing the errors.
    Also, go to C > Windows > Minidump > zip up the files and upload them with your next post, you may need to save them to the desktop first.
    Give us some system specs too.
blue screen of death GhostRayne Gaming 1 30 Jul 2009
HELP!!! Blue Screen Of Death AndyAfrobeast Crashes and Debugging 3 28 Jan 2009
Blue screen of death sqluser Vista General 6 18 Nov 2007
Blue screen comes up randomly NEablis Vista hardware & devices 3 15 Mar 2007
Blue Screen of Death =?Utf-8?B?ZGptMTk1MQ==?= Vista General 6 01 Sep 2006
