laptop CPU upgrade-compatibility questions
  1. #1
    Newbie
    vista home premium 32
    Local Time: 08:18 AM
    not quite an overclocking question but i figured you guys would probably know what to tell me haha
    i have an hp dv6238 laptop
    intel dual core t2250 1.73GHz cpu
    (not sure exactly what other info you need, do let me know. i have everest and can pull most right off there. unfortunately chipset comes up as "unknown" but if you can tell me another way to find it i'll do so.)
    i'd like to upgrade to something
    "2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent"
    having read the dv6000 (which seem to all use the same motherboard) maintenance/service list it suggested intel t7200 as the top (unsure if its top in terms of what was available when it was written or top in terms of what this system can support) but i've had mixed comments on whether its actually compatible so i'm at a loss
    any help would be greatly appreciated
    ideally i'd like something thats pretty much a "drop in" replacement that wont require me to change everythign else and in effect cause me to have to rebuild the entire computer (at which point i may aswell get a new more up to date one since this is about 3 yrs old now hahaha)
    thanks again all
  2. #2
    brummyfan's Avatar
    Brummy
    Birmingham
    Vista Home Premium SP2 32bit.
    Local Time: 09:18 AM
    uk uk england
    Re: laptop CPU upgrade-compatibility questions
    You can upgrade(assuming you have 943GML chipset) to any Socket M cpu here without any BIOS upgrade:
    List of Intel Core microprocessors - Wikipedia, the free encyclopedia
    T2700 is very expensive but T2500 not very far off from T2700.
    If you like C2D, the best value for money is T7200 as T7400 and T7600 are over priced IMO. You have to upgrade to the latest BIOS.
    List of Intel Core 2 microprocessors - Wikipedia, the free encyclopedia
    You also must find out what chipset you have using CPU-z. Post the screen shot of the findings.
  3. #3
    Newbie
      Thread Starter
    thanks for replying so quick, wasnt expecting that
    http://img514.imageshack.us/img514/4553/cpuzzj.jpg
    i just print screened the CPU and mainboard tabs, let me know if you need others
    t7200 looks like it'll be perfect for what i need so thats what i was looking at but i dont want to buy it and then find its not gonna work
    i also wonder, probably the best place to be asking this, my heatsink/fan seems to be a bit dodgy. not sure if its faulty or what
    but from very early on the base of my laptop is so hot its painful to put on your lap (and so lives on top of a book haha but you can still feel its getting hot) and the fan seems to run constantly and is kinda loud at times, is there something better i can put in? or would it be worth getting the same thing and replacing the current one?
    it's very likely it needs a good clean out now, so i do wonder if that could fix the problem
  4. #4
    brummyfan's Avatar
    Brummy
    Birmingham
    uk uk england
    Yes, you can upgrade to T7200 with that i945 chipset. You can use this as guide for cleaning out the fan(it's for an Acer laptop but the priciple is same). Good luck.
    YouTube - How to remove dust from your acer aspire laptop.
    EDIT:
    Use HW Monitor to watch the temps.
  5. #5
    Newbie
      Thread Starter
    finally a difinative answer! haha you have no idea how many different answers i've had (half no and half yes) haha
    is there anything i need to change at all to cope with the new cpu?
  6. #6
    Newbie
      Thread Starter
    as for the clean out, i know the basic clear out. its getting into the damn thign in the first place =P
    i have 2 panels that i can remove, neither of which are near the fan at all, so it'd involve a complete dismantle of the casing
  7. #7
    brummyfan's Avatar
    Brummy
    Birmingham
    uk uk england
    I'm sorry I don't know anything about disassembly of your laptop, you have to find out from another HP forum or google for it. I don't think you have to change anything else. If I were you, I would even try without flashing the BIOS to see whether it works.
    I think people do not like to commit themselves because they do not want to be blamed if anything goes wrong, I am sure you'll take necessary precautions while you do the upgrade like wearing an anti-static wrist band and be gentle with components.
    If you are flashing BIOS, disconnect Internet, disable all background services like Windows defender, AV programs and do not interrupt the flashing. Let us know the success and all the best.
  8. #8
    Newbie
      Thread Starter
    thanks very much for your help
    just had a look at the HP site under updates for my laptop and found this
    BIOSDateVersionPreviousSize
    » WinFlash for HP Notebook System BIOS (for Notebooks with Intel Processors) - Microsoft Windows/Vista-Based
    12-2008F.2D» Version:3.08M
    would it be worth updating regardless of my looking at a new cpu?
    if so, should i do so before or wait til after installing the new cpu?
    there are 5 other versions between the one i have now and the current one... i assume its ok to go right from F.16 to F.2D?
  9. #9
    brummyfan's Avatar
    Brummy
    Birmingham
    uk uk england
    If you are not going to upgrade and your laptop works fine, no need for BIOS upgrade.
    If I were you, I'll fix the new cpu without flashing BIOS and will see whether it recognises the new cpu,if it doesn't recognise, I'll remove the new cpu and put the original cpu and flash the latest version of BIOS and try the new cpu. HTH.
  10. #10
    Newbie
      Thread Starter
    is there a downside to updating the bios without a specific reason?
    supposedly they have newer things to check up on temps and also mention of a fix for a slight lag in wake up from sleep mode which i have noticed which is why i was wondering
Page 1 of 2 12 LastLast
laptop CPU upgrade-compatibility questions problems?
Application Compatibility VRT Questions Answered SGT Oddball Vista News 0 12 Oct 2009
Compatibility OS Questions alienware General Discussion 5 10 Jul 2009
Urgent Compatibility Questions mystic Software 2 04 Dec 2008
OEM Upgrade Questions Marc Vista installation & setup 22 04 Feb 2007
Upgrade questions Bob Daun Vista General 4 31 Oct 2006
