Is it possible to overclock CPU without using BIOS
  1. #1
    United States
    Windows Vista Home Premium 32 bit
    Local Time: 23:16
    usa us california
    Hi, im new to the concept of overclocking, i dont really want to atempt it but i do have a question. Is it possible to overclock CPU without using BIOS? When i go inside my CMOS setup i cant go into CPU settings.
  2. #2
    Vista Home Premium x64/Win7 Ultikmate Technical Preview - x64
    Local Time: 00:16
    canada ca quebec
    Re: Is it possible to overclock CPU without using BIOS
    Hi kato
    It is is possible however I will be providing you with an answer that will not make you happy.
    The best way to approach your concern is to obtain an "overclocking-friendly" motherboard, if your existing motherboard bios has the CPU and voltage settings locked. This is common for OEM vendors. Aside for voiding warranties on your existing hardware, your vendor will not provide any further support on your system if things started heading south as a result of a software-overclock etc.
    There may other posters (Guru's and experienced), on this forum, who may advise you as to how best to achieve what it is you are after.
    Hope this in some way answers your query
    Regards
  3. #3
    smarteyeball's Avatar
    Australia
    7 Ultimate x64 : Vista x86 VM :W8 RP x64
    Local Time: 16:16
    australia au queensland
    Quote Originally Posted by Katokato View Post
    For some setups - Technically yes, advisable no.
    Are these your full specs:
    HP Pavilion a6110n PC (GG781AA) specifications - HP Home & Home Office Products
    It can normally be achieved by using software, however I couldn't find any software based apps that support your chipset (nforce 430)
    Unfortunately, you may be out of luck
  4. #4
    l)ark_Scorpion's Avatar
    The Great Lakes
    Windows 7 Home Premium 64 bit
    Local Time: 01:16
    usa us michigan
    Overclocking is not recommended, EXPECIALLY on a Laptop... Laptops get hot when they are not overclocked. If you overclock and your computer gets too hot, you can kill your motherboard or processor.
    I would recommend you not do it, since you are new, If I were you, I would read more into it, and identify the benefits and the risks...
    When you overclock, you can decrease the life of your hardware by up to half in some cases, but in others, it doesn't deteriorate the life of your hardware, it just depends what your computer hardware you have.
    LINKS:
    The Basics...
    Benefits and Risks...
  5. #5
    Australia
    Local Time: 16:16
    Quote Originally Posted by Snow(ConFed) View Post
    Overclocking is not recommended, ESPECIALLY on a Laptop...
    Psst - it's not a laptop
    Yes, overclocking does have it's shortfalls - but when prepared for and done properly, it can significantly reduce the risk
  6. #6
    The Great Lakes
    Local Time: 01:16
    usa us michigan
    My bad, I'm sorry. Lol. That's the same computer that my mother has, and as I can recall, it doesn't overheat at all.
    Why do you want to over clock it? That computer is fast, and good for gaming.
  7. #7
    Australia
    Local Time: 16:16
    lol, easy enough to overlook.
    But good for gaming?
    It depends on the game and settings I guess - not intending to berate, but that's a rather weak GPU.
  8. #8
    Wishmaster's Avatar
    Ohio
    Windows 7 Home Prem.
    Local Time: 00:16
    usa us ohio
    IMHO, Overclocking should always be done via bios never software. Software OCing is asking for trouble and best to steer clear of them.
    Also, the very first thing that needs to be looked at before attempting any overclocking is the cooling solution.
    The bios are locked for a reason. Generally speaking, most OEM boards simply can not tolerate the stress OCing creates.
    Motherboards that are designed with OCing in mind are a different story, and can tolerate more stress/heat.
  9. #9
    United States
    Local Time: 23:16
    usa us california
      Thread Starter
    Thanks for the reply guys, I dont think I will overclock at this time, and i think i need to learn more about computer hardware and software.
  10. #10
    The Great Lakes
    Local Time: 01:16
    usa us michigan
    Good choice, better safe than sorry.
Page 1 of 2 12 LastLast
overclock my g70
Hello, was just wondering if it is true that I can't overclock my hp G70 120ea laptop? :confused: If it is possible what would be the best way to...
Overclocking & Cooling
Overclock Help
Hey. I could need some helpful tips in overclocking my Intel Core i7 950 3.07 GHz I know there is a lot of guides and stuff about OC but some...
I7 920 overclock
I recently overclocked my cpu from the stock 2.67 to 3.8 Bclk 194 cpu volt 1.4 Dram bus volt 1.50 Qpi/dram core volt 1.375 Temperature was fine...
can overclock gpu
i wana overclock my gpu, it a nvdia geforce 6150se nforce 430. it intergreated graphic card i have riva tuner , bu is it to old to support it?
Ati Overclock
Which is the best and safest way to overclock my ati radeon HD 3870x2?
Graphic cards
Should I Overclock?
Hi, I have been thinking for a while, should/could I overclock my system. I do not have special cooling features.. just 3 Air cooling fans (CPU,...
Overclock 101
k My signature gives you all my system Specs. i was wondering if anyone here has a similar setup and overclocked their system. and hoped they gave...
